Timing Neu Motor
  • electric
    • May 2008
    • 1744
    Timing Neu Motor
    Could someone tell me the timing for:
    Neu 1527/1/Y 1250kv 8mm
    I am using a t180/6s setup.
    Thanks
  • LarrysDrifter
    Big Booty Daddy
    • May 2010
    • 3278
    Start with 11 degrees.
      • 7990
      Jim, most of us are using 15* with that motor. That value works well, supplying plenty of power and reasonable temperatures. Last weekend I used 15* in my Shadow and was running around 70 mph while pulling just 650 mAh per lap. Temps were not above 120* on anything even though it was 90*F ambient.
      • electric
        • May 2008
        • 1744
        Thanks Jay and Larry. Jay, I almost have my Q-hydro together. Might test it out sometime this week after work. I have been traveling a lot lately so not much time for the boats. The good news is I found a big pond that is about 15 minutes from my house so it will be easier to get a few test runs in quickly.
        • electric
          • May 2008
          • 1744
          What kind of amp pull should I expect with the Q-hydro? Sounds like it should not be anything too crazy since the MAH you(Jay) stated per lap would make it pretty reasonable. I would like to hook up my Eagletree data logger (150amp) model to get some readings and I am trying to decide if it will survive the run.
          Adding more:Neu 1527/1/Y 1250kv 8mm
          I know the prop is critical to the amp draw, but let's assume I am running something that has me in the mid-60's. I will have to get the prop number when I get home.
          • longballlumber
            • 3119
            I glad this topic came up. I am going to run my Phil Thomas SS45 this week too. I have 2 choices on motors the 1527 1Y like most others. I also have a 1527 1.5D also. I plan on running the 1Y first to help get the boat set up.
            Can someone reccomend a starting prop?
            Thanks
            Mike
            • T.S.Davis
              • 6228
              Mike, it will take more but just to get it wet I would start with a 452 on the 1Y.
              Noisy person
              • electric
                • May 2008
                • 1744
                Thanks
                Mike
                Mike, for what it is worth, I can give you the prop I am going to use on my Whip 40 when I get home tonight. It is the prop the previous owner used to race with.
                • Serpents811
                  • Oct 2011
                  • 381
                  How about timing on a 1515 1y 2200kv
                    • 7990
                    Terry is right, the x452 is a great prop for heat racing and a good place to start (and perhaps stop). Most of us who tried the 1527/1.5D went back to the 1Y, the latter has plenty of power and is easier on packs. In the last District race I ran the 1Y at ~70 mph using 4400 mAh in 7 laps plus mill - running 1P/6500mAh packs. I'd need 2P to run the 1.5D safely, and it would probably be no faster than the 1Y is - depending on water conditions.
                    • longballlumber
                      • 3119
                      Thanks for the input guys.
                      Have you guys done any testing with 1400 series of props on sport hulls and FE power?
                      Later,
                      Mike
                      • electric
                        • May 2008
                        • 1744
                        Mike,
                        The prop I am going to test is a 1455/3 3.91 T.E Cup, 3.10 C.O.B Pitch and 53.85 DIA. It is a Mark Sholund prop and the previous owner of the boat stated it was the prop he was using to race with sucessfully. All I can say, is that it is huge prop compared to the smaller boats I am used to. Chuckle.
                        Jim
                        • T.S.Davis
                          • 6228
                          55/3 is too much in my opinion. Let us know how it goes though. I tried a 450/3. The motor didn't care at all but my particular boat didn't like the prop.
                          I've been as high as an x455 but highly modified. I don't have any real numbers to share on that prop.
                          Noisy person
                          • Rumdog
                            • 6453
                            We need some kind of timing sticky.
                            • electric
                              • May 2008
                              • 1744
                              That is a great idea.
