i assume you modded the water cooler on the T180, how did you mod yours in the end. Are you running a .150" flex or .187 on the 3674 motor. Thanks.
Leopard 3674 2200kv 5 Cell LiPo help please.
Can i ask what settings you used on the T180 as some have had the lvc cutting in much to soon & have had to set with no lvc & time runs so as not to go to low on battery capacity. Did you experience lvc cutting in to soon at all. Thanks.Comment
Sounds good. I guess there are just so many ways to go. But I still have a stock 1800kv motor from PB Mystic. Maybe I will try 5S on that. I believe I can use the same motor mount out of Miss Geico for each of the motors 1500,1800 and 2030kv UL1
all fit. I believe Leopard will fit also. O.K. last question. What about the 3674 motor with a lower kv on 5s I guess I just want to try one of the Leopard motors just because what I have heard is that they seem to be built nice of high quality but still reasonable price. I get most of my stuff from OSE and like the service and they seem to have a lot.Comment
I would say around 15 laps but this is about what we get around 5 minutes of racing at the local pond. Just a bunch of guys that want to go faster than each other. But a lot of fun. I guess it's an addiction....love it...Comment
I don't use the LVC, I just time my runs and use 7 degrees timing.Comment
With a 3674 2200kv on 4s I'm doing mid sixties on gps in a JAE, still some tuning to be done. 5s puts me in the 70's but I only go for a few passes. I've seen that combo on 6s in the 80's but again just a few passes. I wouldn't run that motor consistently on anything higher than 4s.Comment
Don't have any tricks I know of. It's an all stock build including hardware. Using a .150 shaft with liner and the prop is back cut slightly and B/S, Gens Ace 4s 30c lipos cog at 13.5". Just had it out today and was hitting 60.8mph on GPS with 4s and a little chop. Thought I'd get more top end speed over the UL-1 but this is all I can squeeze, does have a lot more torque though and pulls out of the corners. Doesn't like the chop as much anymore with the added weight but I think I'm getting too much lift with the prop at the higher RPM. Need to take some lift out of it next, maybe try an S-15.Comment
Check out this vid , this my rigger And let me know what you think
http://www.youtube.com/watch?v=nydmD...e_gdata_playerComment
Looks good, wish I had glass to run on like that. The H-7 would scream on that water, make sure it's B/S well. Can't tell ya why the speeds are different, I'm heavy with all the paint I layed down and the new cowl I made, so I'm not sure. Come to the West Coast and we'll see!Comment
So what is the difference or should I say the advantage of the the 4074? You are talking running on 4s? Running a bigger prop I assume? Can I still run it on a .150 shaft? Also what kv for the 4s pack. Thanks.Comment
