Leopard 3674 - 2650kv on 4s,will Seaking 120a esc be enough
  • martin
    • 2869
    Im looking at using the above motor in JAE 21 hydro, so around 39000 rpm unloaded. Will a HW Seaking 120a esc handle this or should i look towards a Swordfish 200a. Also would the Seaking 120a be ok on a Leopard 3674 2200kv on 4s or would a 200a esc be better as well. Thanks Martin.
  • jkr
    FE Addiction
    • 568
    Yes.
    I use Hw 120a 4s 1p with leo 3674 2200kv timing 3,75 and i run it with 45mm prop on 27'' mono
    • martin
      • 2869
      Yes 3.75 degrees timing on that motor is good as its a d wind motor, im a bit concered going to the 2650kv motor though on the 120a esc as its a higher amp motor than the 2200kv.
      • keithbradley
        • 3663
        Both of those are a ton of motor for a 120A ESC. I've ran a 2200kv motor on a 120A ESC before, but it's not reccomended.
        I guess it all comes down to the prop you run, but IMO if you run anything over a 440 I think the 200A would be a better choice.
        www.keithbradleyboats.com
          • 9479
          link
          do you have a link to this motor?
          I have something it may work wonders in!
          • jkr
            FE Addiction
            • 568
            You can run it with 42mm but if you want bigger esc better buy a t180.
            I like how easy they are (120a-180a)
            • martin
              • 2869
              Yes i will be sticking with a 180-200a esc. Martin.
              • Make-a-Wake
                FE Rules!
                • 5554
                Leopard 3674 - 2650kv do you have a link to this motor?
                I thought there was no such thing..............but it does exist!
                • jkr
                  FE Addiction
                  • 568
                  The 3674 motors have almost any kv for any aplication!
                  • martin
                    • 2869
                    Yes iv been using Leopard spec sheets for a long time now, www.leopardhobby.com. Theirs spec sheets on every motor they make in all sizes.
