Seaking 180-leopard 3674 2650kv timing???
  • JIM MARCUM
    • Jun 2011
    • 773
    Any suggestions for what the timing should be with the above ESC/motor combo in an Apparition Offshore at? Could use some help on this one. THX, JIM
    JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
  • Diesel6401
    Memento Vivere
    • 4204
    That motor is a D wind. Try 7.5 or a little lower. I ran my D wind at 7.5 with good results though.
    - Diesel's Youtube
    - Diesel's Fleet
    • JIM MARCUM
      • Jun 2011
      • 773
      Thanks Dale. I forgot to mention I'm running 4S 2P. I read a thread that recommended 11.25 degrees, so I set it at that. Does any of this change your advice? I'll drop it to 7.5 if you think that's best. JIM
      • Diesel6401
        Memento Vivere
        • 4204
        11.25 is recommended for "Y" wind leopard motors, yours is a "D" wind meaning lower timing is recommened. At 11.25 with your motor, I think you'll see increased heat with less performence. My "d" winds I wouldn't and haven't run that high. Voltage doesn't matter with timing. 7.5 or lower is still what I would suggest... JMHO
        - Diesel's Youtube
        - Diesel's Fleet
        • JIM MARCUM
          • Jun 2011
          • 773
          Will do Dale. JIM
          • ice_spy
            • Nov 2008
            • 122
            Seaking 180HV with leopard 3400kv
            Im looking at a twin set up, in an Apparition 820mm cat that i have lying around.
            I wanted to use 2x leopard 2860 3400kv BL's with 2x Seaking 180A HV esc's on 4S with 2x 4S packs 35-70c for run time and amp draw.
            Im trying to brake the 100klm mark. I will be running the 70mm outdrives drives with 4mm shafts and 2x venom 32mm cnc pro alloy props counter rotation set up for less walk.
            My question is after reading this thread, is the Seaking 180A hv esc's going to be suitable for the leopard 3400kv motors ? Being 4 pole i didnt think about that.
            I wanted to go a higher amp ESC like the 180's as im thinking these days, until i get a data logger, bigger is better for amp draw. 120's would probly be ok, but for the little xtra money and features the 180's sold me to be on the safe side.
            Would anybody know the timing setting for these motors with the seaking 180a esc's ? can i place a 63v 1000uf 105'C cap on the esc to make it even better? how do i tell if the motors are 'Y' or 'D' wind motors?
            • martin
              • 2887
              That 2860 motor is a D wind, if you go to Leopard hobby theirs all the specs on their range of motors motors. You need low timing on the D wind, i would use around 3 degrees. Martin.
              • JIM MARCUM
                • Jun 2011
                • 773
                I was gonna reduce timing to 7.5 today but was in a hurry & left it at 11.25. Ran my Apparition thru 4 batts (4S2P) without any motor/ESC desoldering or motor overheating. I did run a separate H2O pickup & changed out the restrictive motor jacket nipples, so that may explain, in part, the temp drop. Will try 7.5 degrees and 3 just to measure the speed difference. JIM
                • Diesel6401
                  Memento Vivere
                  • 4204
                  If you hooked up a eagle tree and stuck a temp sensor on the motor itself you should see the motor running more effcient at the lower timing.
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • JIM MARCUM
                    • Jun 2011
                    • 773
                    So you are saying that I can get more speed in this application by lowering the advance? If so, what would you recommend: 7.5 or 3 degrees? JIM
                    • Diesel6401
                      Memento Vivere
                      • 4204
                      No not necessarily more speed, I'm saying more effcient i.e less excess heat and possible lower amp spikes (without data logging you won't be able to tell though), which may increase realibilty, which is more important then speed IMHO... after all speed is just a number right...
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • stadiumyamaha
                        • 1284
                        +1 on that
                        white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
                        • JIM MARCUM
                          • Jun 2011
                          • 773
                          Thanks guys, I will buy a data logger. This setup is for SAW racing. The goal here is to break the P Offshore class SAW record. If the motor frys at the end of the second pass & I break the record that's OK with me. Speed is everything in this application. I just don't want my boat taken out by a turtle. Again. JIM
                          • sampit
                            • Jul 2009
                            • 447
                            iv used the 2860kv leopard motors in a mono1 hull with 39mm prop great motors
                            i was going to build the same twin setup in my Appartion
                            theres a guy on utube running the sam setup with two T120 it goes well
                            see if i can find it
                            FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
                            Popeye Hydro T600 1400kv 6s1p
                            • ice_spy
                              • Nov 2008
                              • 122
                              Heres an Apparition on 4S with twin lepards, is 2860 the size of the can, and not the KV?
                              This is what i want to copy for my Apparition wtin set up, seems to be going a fair speed.
                              Also heres another apparition with similar set up on 6S, say its doing 118 klm.
