Just got my motor yesterday. It looks nice and looking at the pics of the leopard 4074 they look identical apart from where the wires exit the can.
Turnigy xk range of motors. Anyone tried them?
I just ran the 1600(box says 1500) 4082 in the Spartan I built with a 200A "Birdie" ESC today and the boat ran flawless swinging a 48mm carbon prop powered by 2, 5000mah 20c zippy $16 packs, for 4s. The warmest thing were the batteries which were barely noticeably warm. ESC and motor were as if they were never ran. I wanted to run 6s but didn't get a chance too due to my recieved getting wet. I have a leak somewhere
A+ stuff in my book!Comment
I was looking at those birdie esc's but thought they looked a bit too cheap. I take it you would reccomend them then?Comment
Definitely, but it did need a little work. More like preventive measures.
I took the heat shrink off and found the cooling plate was touching the motor leads. Also noticed the thermal transfer tape was only touching a few of the FET's. I sanded them down since they had some kind of epoxy over them and installed the cooling block using silicone based, heat transfer paste that I bought at Radio Shack. After that I bench tested it, it worked, and I applied "plastic dip" over it. It bound to my transmitter and took programming on first try. So far, so good.
I'm going to order some more since the t-180 in my Geico didn't want to work after taking 3 months off. Worked fine last time I used it. Today, I tried everything and could not get it to go full throtle. I'm done spending more than $50 for an ESC.Comment
Saw that. They seem to be built the same. At that price I would go with the Keda but don't know how much difference it would be between the 4074 and XK 4082.
I might still pick up a 1300 and a 2030 though.Comment
