Steven, if you get more of these motors in, I would like to test the 1200 kv. I have a 1200 KV Fiegao and a 1200 KV KB45 to compare it to on the lake. I will gladly pay for it.
New Big Boy Motor
ReddyWatts fleet photo
Mean Machine - Feigao 540 14XL, 8s, 100 amp HV esc, X537/3 -
I would replace the KB45 1200 kv in the M1 Supercat. I think it should handle the extra weight ok. It would be a good comparison using the same voltage, hull and controller while finding what the amps, prop and speed difference are in the three. I have already tried the Fiegao 1200 kv motor in this hull. This is a pretty versatile hull.Last edited by ReddyWatts; 12-08-2007, 02:53 PM.ReddyWatts fleet photo
Mean Machine - Feigao 540 14XL, 8s, 100 amp HV esc, X537/3Comment
In order to make it shine I think its going to need a hull running 8s. But I could be wrong.
I want to run one in a 44" sniper on 8s to see how it goes.Steven Vaccaro
Where Racing on a Budget is a Reality!Comment
That is what I am running the 1200 kv Fiegao and KB45 on. 8SReddyWatts fleet photo
Wow a boat that size with a feigao xl and 8s. What prop are you running. I didn't realize it could push that much.Steven Vaccaro
Yep, it was running about 40. I posted a video on here somewhere.
Here is the 1200kv Fiegao running on sport Tenergy batteries. 8S voltage
This is the 1200kv KB45 with the same 8S setup on IB3600 cells.
Here is the 14XL Fiegao running on sport Tenergy batteries. 8S voltage
This is the KB45 with the same 8S setup.
http://www.rcflix.com/photopost/show...00&ppuser=3055
thanks for the links. i remember that now.Steven Vaccaro
Y537/3 direct drive on both. Running the smaller prop is like running them on a trans allowing higher rpm and speed.Last edited by ReddyWatts; 12-08-2007, 04:23 PM.ReddyWatts fleet photo
FeCalc says the 1200kv motor on 8S with a X640 prop will use 88 amps and run over 50mph. 2550 Watts. 31000rpm
The Y537/3 will use 60 amps at over 50 mph, if this is truly a 60 amp max motor. 1800 Watts. 32000 rpm
I can try this motor with these props on 8S in the 34" supercat hull for the best speed and keeping the amps low.
It will turn the larger props on 6S and run in the 40's for larger hulls.
Thats my 2 cents worth.Last edited by ReddyWatts; 12-09-2007, 12:08 PM.ReddyWatts fleet photo
I have the 34" M-supercat.
Thanks, I corrected the previous post, It was misleading.Last edited by ReddyWatts; 12-09-2007, 12:04 PM.ReddyWatts fleet photo
