New Big Boy Motor
  • Steven Vaccaro
    • 8723
    New Big Boy Motor
    I just received a new motor in the mail. I'm waiting on the performance specs.
    Its the motor on the right. For reference I included a feigao xl on the left and kb45 in the middle. its 52mm in diameter and 28 ounces. The kv on the particular sample is 1200, but I can get a few different kv's. I will be testing it over the next several weeks.
  • RCprince
    • Jul 2007
    • 1637
    That might be the one for the Rio, Steve.
    • ReddyWatts
      • 1711
      Is that a 10mm shaft?
      ReddyWatts fleet photo
      • Steven Vaccaro
        • 8723
        it has a 8mm shaft
        • Darin Jordan
          • 8335
          Hmmmm.... Something in the either 850 or 1000 KV range??? Would this be a 1/8th scale candidate??
          Darin E. Jordan - Renton, WA
          • raptor347
            • Jul 2007
            • 1089
            A budget 1/8 motor would be way cool.
            Steven,
            It's a 2 pole?
            Brian "Snowman" Buaas
            Team Castle Creations
            NAMBA FE Chairman
            • Doug Smock
              Moderator
              • 5272
              Interesting...
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • Steven Vaccaro
                • 8723
                Its a 2 pole. I was a bit let down to hear this morning thats its only rated for 60 amps. Has a max of 50k rpm and 2.5kw.
                • Eyekandyboats
                  • 1921
                  awe!.8
                  I bet that motor would go great as a low cost motor for a 1/8th
                  Or just a fun motor for a large boat.
                  Thanks Steven.
                  EYEKANDYGRAPHICS
                  www.rclipos.com
                  • Bill-SOCAL
                    • Nov 2007
                    • 1404
                    Airplane prop and a water jacket?
                    I LIKE it!!!!!!!
                    Don't get me started
                    • Steven Vaccaro
                      • 8723
                      I LIKE it!!!!!!!
                      lol, that's my feigao test motor. I change prop sizes to put different demands on the esc's I'm testing. The water jackets on there because it was the first sample I tested for leaks. For those of you who have never played with rc planes, you wouldn't believe how much thrust a 10xl motor on 12 cells will deliver. Its quite scary. My main fear is the prop coming off for some reason. This winter I want to build a lexan box to put the motor in while testing.
                      • raptor347
                        • Jul 2007
                        • 1089
                        What kV's can you get? Any idea what the Rm and Io values are?
                        2.4kW is running 40V @ 60 amps. It may be a bit more capable than the numbers indicate.
                        NAMBA FE Chairman
                        • Bill-SOCAL
                          • Nov 2007
                          • 1404
                          Steven,
                          It's a 2 pole?
                          Of course what you mean is figuring out a way to run it on 30S in an AquaCraft King's Ransom
                          I can just see it now!!! :D
                          • Steven Vaccaro
                            • 8723
                            I asked, but so far no response.
                            • Steven Vaccaro
                              • 8723
                              These are the specs on the motor I received.
                              KV: 1200
                              Resistance: 0.0264ohm
                              Io: 1.4A
