Fluid im 99% sure the bearings in the 3674 motor are the same bearings they use in the 40 series leopards, those are 5mm id x 16mm od x 5mm wide. These are standard size 625 2z or zz depending on manufacturers spec, chrome steel bearings with 2 metal shields. The 2z or zz is 2 metal shields, if you want ceramics their still a 625 bearing but with diff spec numbers.
Leopard 3674 Bearings
Thanks I succeded taking it apart in the meantime. Did a bit differently though. I held the motor in hand, but used a copper hammer to hit the shaft and it worked.
Next question: where do you get your replacement bearings from? And is the ceramic bearing hype worth the extra $$?
I say their worth their weight in gold in my experience.Comment
My leopard 3674 1900kv motor has 5x11x5mm bearings in it.
this was checked by a bearing store but they did not and could not get them so I stoped by my lhs which I should have done in the first place and found some from thunder tiger, part number pv0059.
the package says high peformance. these were in the heli dept.
I will install them tonight or tommorrow and let you know how they work.
the price was 6.99 for two.Comment
Well I installed the new bearing in the 3674 1900kv leopard motor and everything seems fine, the motor spins ok with little noise, not as quiet as the orginal but you can tell its not bad.
this was the first time doing this and it was a piece of cake.Comment
