Need Help with newest 180A SeaKings
  • Mrlocky
    • Jan 2017
    • 4
    #106
    Yes. That was me Trev was talking about a few post back.
    I had tried everything. Even tried lifting the strut to get the nose up more until it couldn't bite.
    I ended up with a 6v 1600mah pack hooked into the rx and it solved the issue straight away.
    Now that it runs I was able to race over the weekend and after a 5 lap race I still have 45% battery left and really cool Temps. Easy to say amp draw was not an issue in my case.
    Cheers
    Locky
    • RCKong
      • Sep 2009
      • 1545
      #107
      Hey guys I'm just gonna put this out there for you that the V3 T180's are JUNK... I've been round and round with HK on this. they have replaced 3 of the 4 defective V3 ESC and I've scraped running them period. Every one in our club is or has had problems with these so save yourself a few bucks and the trouble. I've cleaned out BURN residue from my P-Mono Now 3 times from this POS ESC...
      • Mrlocky
        • Jan 2017
        • 4
        #108
        Hi all just to add some more info.
        Even though i got my boat to run fine with a separate battery pack to the rx mine will still only run with a 70c battery. Also propped up some more until coming in with 30% left after a race.
        On the weekend some fellow racers loaned me a set of batteries to run a final as i only had the one pack and didnt have time to charge. Ended up on my lid in the last heat and didnt require them for the final anyway.
        After racing i went to run the packs down and because of a slightly lower C rating the esc still cut off again.
        Conclusion from that was that a high c rated pack is still required regardless.
        Cheers
        Locky
        • topfuel443
          • Nov 2011
          • 82
          #109
          Well, after reading for an hour about this, it seems we still have no solution.
          I have the EXACT problem as Don and Mic, and cant get these damn things to work. Don or Mic, have you guys made any progress on the V3 ESCs?
          • Steven Vaccaro
            • 8721
            #110
            I'm not saying you don't have an esc problem because it's impossible to say from this side of a monitor. But This was a big problem when the first v3 esc's came out. It was resolved. The only issues I've seen since then I have been instances where the esc's were over amped and shut down or weak packs were used.
            Sent from my SM-N950U using Tapatalk
            • topfuel443
              • Nov 2011
              • 82
              #111
              Steven, I’m not buying it. I have 4 of these V3s and they are all various versions of V3. I also have 3 of the V2’s and none of them have this issue. They are all on the same exact setup. 4082 Leopard, 1600kv, M445 props with brand New (literally brand new) 75C Graphene 6000 MAH 6S lipos. I’ve run the V2s with this exact setup for 7 years with zero issues. I’m talking about race conditions, not just playing out at the lake.
              I talked to Don Huff about it, I’ve talked to Mic Halbrehder about it, I’ve talked to Doug Smock about it. It’s an issue, and Turnigy/Hobby King hasn’t done anything to fix it apparently.
              I wish I had known beforehand, I would not have wasted $500 on 4 of these ESCs. It is what it is, now I know. But there is most definitely an ESC problem.
              • zooma
                Local club FE racer
                • May 2014
                • 652
                #112
                Yeah. I won't buy another Seaking 180 V3 until there are multiple reports of success. Amazing that the manufacturer just won't come up with a version that works. POS.
                Ron - The Villages, FL
                • ray schrauwen
                  • 9472
                  #113
                  Too bad we can't get V2 back. They are shooting themselves in the foot.
                  Nortavlag Bulc
                  • ray schrauwen
                    • 9472
                    #114
                    I asked for one and they said they no longer make them. If we or someone asks for 100 or more, maybe they will make a batch?
                    Nortavlag Bulc
                    • topfuel443
                      • Nov 2011
                      • 82
                      #115
                      Ive got 3 of those Ray and they are bullet proof. Ive been running them for years in my race boats. Too bad the V3's fall short.
                      • Panther6834
                        • Apr 2020
                        • 708
                        #116
                        I see there have been no updates related to the 'ESC early shutdown' problem in over a year. Does that mean the problem has been completely resolved? Or, does this problem still occur? Does the firmware need to be updated to a certain version (or higher), and, if so, what is the minimum firmware version number? Speaking of firmware, can the 180 V3's firmware even be updated?
                        Moving over to the programming side of things, do both programming devices (ie. Multifunction LCD Professional Program Box, Program Card for Seaking Boat ESCs) work with the 180 V3, or does only one of these work (and, if so, which one)? Going another route...not sure if anyone has even attempted this...can the Hobbywing WiFi Express Module be used for programming (and updating the firmware)? I've read that the WiFi Module can be used with certain HW Seaking ESCs, but I haven't found anything indicating specifically which Seaking ESCs. As I have off-road vehicles, I already have the Multifunction LCD Box, as well as the WiFi Module, and I'm hoping that at least one of them can be used with the 180 V3.
                        ~ More peace, love, laughter & kindness would make the world a MUCH better place [emoji1690]
                        • Scott T
                          • Oct 2007
                          • 590
                          #117
                          Going by the Hobbywing website, only the older LED program box can be used (click on Specifications). http://www.hobbywing.com/goods.php?i...attr=6639.6640
                          Their newer Pro series marine ESCs can use the LCD box or WiFi.
                          Scott Tapsall
                          Pine Rivers Model Powerboat Club - Facebook Page
                          My Gallery
                          • eric113
                            • Sep 2011
                            • 323
                            #118
                            I bought a 180 V3 off a club member. I was running with Leo 4070 1650kv on 4s no problems. Switch the motor to TP 4050 2300kv motor on 4s(yes I realize TP are amp hogs) I started to have cutting out problems. It would run then stop. Then I could go again. I added a bec, seeing if that would help with the cutting out. It was still cutting out. I really wish seaking would remake the V3?s back to V2?s and make them a pro model. Also wish they would up it to 200amp.
                            • donhuff
                              • Dec 2014
                              • 561
                              #119
                              Eric, since you increased the peak rpm of the motor by almost 10,000 rpm, I hope you reduced the diameter of the prop by about 10 mm.
                              And I'm curious as to why you say the TPs are "amp hogs" ? I guess it's because you have read this before. I keep hearing this about different brands, but I never hear any reasoning for anyone saying this.
                              AmpDaddy
                              don huff
                              • fweasel
                                master of some
                                • Jul 2016
                                • 4286
                                #120
                                As don mentioned, hopefully you propped down. What is the LVC set to? Your batteries may be experiencing more voltage sag on the new setup and tripping the LVC too early. I've had trouble with overly sensitive LVC on the V3 ESC, and usualy just disable it by default since I time my runs.
                                Vac-U-Tug Jr (13mph)
