Need Help with newest 180A SeaKings
  • donhuff
    • Dec 2014
    • 561
    #76
    I'm curious. Does your turnigy have six (6) caps on the power leads?
    only the newest batch of seakings hav 6, and they are the only ones that give the problem.
    AmpDaddy
    don huff
    • Tamelesstgr
      • Jun 2014
      • 1516
      #77
      My turnigy version has 3 caps on the main body and then 4 caps on the power leads.
      NEVER SATISFIED RACING
      Fine Design 32 V-Hull 4082+6s
      • donhuff
        • Dec 2014
        • 561
        #78
        yeah, that's not the bad one. They only have two little caps on the main body.
        AmpDaddy
        don huff
        • Tamelesstgr
          • Jun 2014
          • 1516
          #79
          Apologies, the V3 that I have does have 2 smaller caps. I also have a V2 which has 3 larger caps.
          • donhuff
            • Dec 2014
            • 561
            #80
            Ah ha, The top pic is the correct one, but on the power leads, red and black, are there 2 or 6 caps?
            If just two your good, if 6, then you got a problem. But if you have run it, you would know this.
            AmpDaddy
            don huff
            • Tamelesstgr
              • Jun 2014
              • 1516
              #81
              I have 4 caps on my power leads, I'll try and get a pic later
              • TRUCKPULL
                • 2969
                #82
                [ATTACH=CONFIG]149783[/ATTACH]
                [ATTACH=CONFIG]149784[/ATTACH]
                The bottom picture is a V2 - They are OK
                Larry
                • Peter A
                  • Sep 2012
                  • 1486
                  #83
                  I got it! The fix for the problems would simply be to go back to the V2 version that worked well. I have two that get a lot of use and have even been dunked but still keep going. The V3 version isn't as good so dump it and remake V2's. That's some consumer feedback for Hobbywing.
                  • TRUCKPULL
                    • 2969
                    #84
                    Here is the full picture of the V3
                    The caps are under the shrink on the power wires.
                    It also has a switch wired to the ESC.
                    Larry
                    • Doug Smock
                      Moderator
                      • 5272
                      #85
                      Originally posted by donhuff
                      Dang, that was quick!
                      Just heard back from Charlie. They are aware of the problem and are working on a fix. Here is part of the email he sent me.
                      Hi Don,
                      Good news is, we have been working on this exact topic. Bad news is that I am un clear as to exactly "when" and "how" we're going to initiate the fix for current owners and users. I need a bit more time, as we're still "confirming" the fix is working in the field, but, as soon as the testers report back, we'll be working on getting updated units exchanged for customers.
                      For anyone having the issue, I suggest that you email Charlie and get you process started [email protected] B
                      edit... They call the problem "Early Shut Down issues". When communicating with them, I would use this term to describe your problem. Might save you some time trying to explain things!
                      Great news. Guys Steven is on this as well.
                      Thank you Charlie & Co!
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • golfito
                        • Sep 2011
                        • 296
                        #86
                        Good thing they're dealing with the problem.
                        Is there anything that identifies which batch of fa is defective?
                        • donhuff
                          • Dec 2014
                          • 561
                          #87
                          Yes, they have SIX caps on the power leads.
                          AmpDaddy
                          don huff
                          • Revolt Flash
                            • Aug 2015
                            • 437
                            #88
                            Hobbywing answered me yesterday and told me to start a couple of RMA's.
                            • cocos710
                              • Nov 2016
                              • 6
                              #89
                              Hi...Were can we find the correct RMA Form?
                              • Revolt Flash
                                • Aug 2015
                                • 437
                                #90
                                What I did was send Charlie [[email protected]] an email about the Seaking 180 v3 esc early shut down issue and Hobbywing sent me the info. and directed me in what to do.
