Swordfish 300amp HV Lite Wiring
32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
The coating is called a conformal coating. They are commonly used to insulate electronics. There are Silicone and Urethane based conformal coatings plus several other specialty ones. Most hobby coatings are silicone based.
TGTyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WRComment
On my 1p setups, I brought soldered both wires into the connector end of a female 8mm bullet, then a short wire out the other end, along with a pigtail for the caps.
On the 2p setup, I soldered each wire into it's own 8mm bullet normally, then stripped the main wire an inch or so back and piggyback soldered on wire that jumps from one to the other. This jumper wire was stripped in the middle and soldered to the cap bank. I'll see if I have any pics when I get to my computer.....
These have worked well for my applications.Last edited by kevinpratt823; 05-20-2015, 05:24 AM.My private off road rc track
https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8Comment
1p
2p
I know the pigtail methods are not perfectly ideal because they are not directly on the power wires, but I have plenty of headroom on both the capacitors and esc., and this was far more feasible for the space i had to work with. The 2p setup has run flawlessly for a few seasons in my Sniper 45" @well over 225 amps, the 1p setup is in the KBB45 twin, and has only seen about 10 runs, but was good enough to break 100mph on gps @ 160 amps.Last edited by kevinpratt823; 05-20-2015, 05:38 AM.My private off road rc track
