Esc going into protection on blackjack
  • montymike
    • Jul 2012
    • 774
    Lower lvc solved problem.
    • CraigP
      • May 2017
      • 1464
      The terminal voltage of the battery drops under load, according to its IR. Also, poorly made wires or bad connectors also drop volts. If you have an IR, check all your connections and wire links after a run. Maybe you need an upgrade. 120a is pushing a 5000mah towards 50C, so you need a healthy electrical system!
      • NativePaul
        Greased Weasel
        • 2760
        120A on 5000mAh is 24c.
        • Bp9145
          • Jan 2016
          • 1466
          Uh oh. .
          • montymike
            • Jul 2012
            • 774
            120a esc , 6000ma 70c updates when i changed lvc to lower setting works fine.
            • CraigP
              • May 2017
              • 1464
              Yes, brain fart!
              • montymike
                • Jul 2012
                • 774
                L.o.l. i do it all the time.
