Seaking Pro 120A
  • Mxkid261
    • Jun 2015
    • 734
    Seaking Pro 120A
    Was poking around and noticed this, anyone run one of these or is it a completely new unit?
  • Tamelesstgr
    • Jun 2014
    • 1512
    OOH, that's promising as I am looking for a 120 for my outrigger build
    Features Specifications Downloads Lightweight and compact, making it suitable for mini boat competitions. Equipped with a powerful switch-mode BEC, delivering a continuous current of up to 5A and a peak current of up to 10A, with adjustable voltage support (6V/7.4V/8.4V) to easily drive various high-performance and hig
    NEVER SATISFIED RACING
    Fine Design 32 V-Hull 4082+6s
    • Tamelesstgr
      • Jun 2014
      • 1512
      • Tamelesstgr
        • Jun 2014
        • 1512
        Also looks like the wifi express module will allow smartphone access to changing parameters in the esc, and looks like some Datalogging capabilities?
        • Peter A
          • Sep 2012
          • 1492
          You mean this one?
          http://www.offshoreelectrics.com/pro...eaking-120-pro
          Looks like Steven is already stocking it.
          • Tamelesstgr
            • Jun 2014
            • 1512
            He must have just put that up on the site
            • CraigP
              • May 2017
              • 1464
              It's low voltage and single-sided cooling, but looks good for smaller boats. Bunch of features!
              • ray schrauwen
                • 9438
                Directed more at the European market for weight restricted classes. I'm sure they are very good escs for many applications however hifei is coming out with new stuff also, x series. They are geared to non weight restriction running with robust cooling and being potted.
                • CraigP
                  • May 2017
                  • 1464
                  Nice, got a Seaking 130A-HV for my 8S system now... I like that data logger in another unit, name escapes me at the moment... The more cooling, the better! I'm using a 35% derate on the ESC. These things are just like FETs, the stated voltage rating is not really usable...
                  • CraigP
                    • May 2017
                    • 1464
                    Yeah, just checked.. Looking at the Swordfish Pro+ 150A HV, with data logging. Seems to me, they will rule the market until competition puts data logging into their units. Can think of no better way to help evaluate boat changes. Next, built-in GPS, nice!
                      • 8750
                      This is pretty neat!
                      • CraigP
                        • May 2017
                        • 1464
                        It's a good one, looking st my SeaKing, wished I hadn't bought it yet...
                        • Insanity Plea
                          • May 2017
                          • 562
                          Would this 120A be sufficient to run with a 2030kv out of a UL1, or would the 180 V3 work better? My plans are to put this set up in a stiletto with a smc 5200 90c 4s2p. Im experienced with large scale gas but new to electric and still figuring things out.
                          If another motor/esc combo would suit a tunnel hull better, I'd be open to suggestions. Thanks
                          IMPBA 20583
                          • ray schrauwen
                            • 9438
                            You will be fine with that esc on a 2030Kv yellow can motor.
                            • CraigP
                              • May 2017
                              • 1464
                              Ray is right, it SHOULD be fine. But realize that a BLDC motor will not current limit itself. IF you have something out of whack, too much prop, running too wet in the water, sticky driveline, anything like that, the motor will continue to pull current and burn the motor and/or the ESC. That is why I switched from the Sea King ESC to the Swordfish, so I can get a data log of the running current, and bring my setups slowly to higher performance levels. The only other way, is to run carefully timed runs and do thermal readings and chart what is going on. But I feel thermal readings are not enough. You may be running too cool, and leaving some added performance off the table. Your current levels may be fine, but your water system is not functioning properly to provide the needed cooling. After using the Swordfish, I'll never go back to an ESC that does not have data logging. These are getting so popular, it's hard to get your hands on one at times!
