What is the difference between a car ESC and A boat ESC?
  • boilo56
    • Aug 2014
    • 390
    Hi everyone, i would like to know what is the difference, exept for the watercooling?
    thank you!
  • egneg
    • 4664
    Car esc's are typically sensored and boat esc's aren't.
    IMPBA 20481S D-12
    • JimClark
      • 5902
      I am guessing the throttle curve might be way different for a boat vs a car
      Billy Graham
      • boilo56
        • Aug 2014
        • 390
        Ok, i should have mentionned that i'm using a MambaMonster2 ESC. I made a custom cooling to it. The Esc is unsensored and fully programable. That being said, what would be the difference between the two throttle curves? Mine is linear right now. Is it ok?
        • keithbradley
          • 3663
          Usually reverse, engine braking.
          www.keithbradleyboats.com
          • ray schrauwen
            • 9438
            sORRY, THOUGHT YOU meant XL-2... caps, ooops.
            • photohoward1
              • 1614
              They are the same it is usually just the programming. Linear is Linear. Turn off Braking and reverse.
                • 8750
                I run a mm2 in my 26" cat. I still have the reverse operable as I sometimes do need to back up...if you hammer on it in reverse you will unwind the flex, so be careful. This esc is only 120 amps so you have to choose your setup wisely. It does have an overheat protection so that's a plus. I personally like a car type throttle curve anyway, I find it smoother. I milled the fins off mine and made a block for it. It works pretty well.
                • boilo56
                  • Aug 2014
                  • 390
                  What does that means???
                  • boilo56
                    • Aug 2014
                    • 390
                    Thanks for the pics! I only dremeled some of the fines to insert aluminium tubes between them. Are the caps really necessary?
                      • 8750
                      I always use them....extra insurance.
