120 a sordfish cooling help
  • montymike
    • Jul 2012
    • 774
    Picked up the older version of the 120 a sordfish with cooling on one side? Thinking of adding a cooling tank have
    Laying around. While im waterproofing and adding caps to it. My question is would jb weld be good to use to glue
    To cooling plate for good heat/ cool transfer.
    • 7651
    You should use proper heat sink compound. There are some that dry like silicone and some are grease that never dry.
    • montymike
      • Jul 2012
      • 774
      Have used the stuff that never dries. Were do i get stuff that does?
        • 7651
        I got mine on eBay Fujiko I believe. I am going to hobby room right quick here, I will dig it out.
          • 7651
          Here it is:
          50ml Thermal Fujik Silicone Adhesive Glue Grease Coupling CPU Heatsink Compound
          Item # 231039921286
          And an email addy for Karina hobbylott@gmail.com
          I just used this stuff to redo the cooling on two Castle ICE 200 HV controllers. It worked very well for gluing new cooling blocks to the fets
          • montymike
            • Jul 2012
            • 774
            Ok not gluing directly to the fets the cooling plate is glued to them just gluing to cooling plate still need it?
            • montymike
              • Jul 2012
              • 774
              Thanks for the info. Mike
                • 7651
                You need to transfer the heat from one source to another. I am not sure of JB's thermal conductivity.
                • rickwess
                  • Apr 2013
                  • 777
                  Be sure to get the Arctic Alumina and not the Arctic Silver.
                  • montymike
                    • Jul 2012
                    • 774
                    I have heard of the stuff where do you buy it? Thanks mike
                    • ray schrauwen
                      • 9438
                      Ebay or Amazon or??
                      ARCTIC SILVER EBAY
                      Characteristics:
                      Arctic Alumina Adhesive uses a layered
                      composite of aluminum oxide and boron nitride.
                      Arctic Alumina Adhesive is a pure electrical
                      insulator, neither electrically conductive nor capacitive.
                      A set of Arctic Alumina Thermal Adhesive
                      consists of two tubes containing a total of
                      5 grams of adhesive (2.5 grams each of parts
                      A and B) and a plastic reusable mixing wand. (Approximately 3cc total adhesive.)
                      Although lighter per set than Arctic Silver
                      Adhesive due to its use of ceramics rather than silver, each set of Arctic Alumina Adhesive
                      contains the same amount of adhesive by
                      volume as a set of Arctic Silver adhesive
                      and will cover the same area.
                      • montymike
                        • Jul 2012
                        • 774
                        Thanks ray
                        • montymike
                          • Jul 2012
                          • 774
                          ordered some from newegg
