castle ice 200hv
  • meangenesracing
    • Jun 2012
    • 1158
    castle ice 200hv
    just fried my second brand new esc 1 run each on 10s setup any ideas whats up any help would be great thanks
  • JimClark
    • 5907
    people will need more info as to your setup and how long you ran it for ect
    Billy Graham
    • meangenesracing
      • Jun 2012
      • 1158
      boat is a aeromarine conquest cat with a castle hydra ice 200hv esc and castle 2028 780 kv motor octra 465 prop. the water was running through both lines 1 to motor and the other to the esc. only ran for about 5 min. on each esc and just burnt right up ive seen a few of the same setups here and on youtube just can noe understand why im haveing this problem someone please help thanks, geno
      • keithbradley
        • 3663
        Have you logged current draw with this setup?
        www.keithbradleyboats.com
        • meangenesracing
          • Jun 2012
          • 1158
          dont know if i can check it with my castle link controller wires all burnt right off dont i have to have it hooked to my lipos. im all new to electrics im have all gas thanks, geno
          • titan29
            • May 2010
            • 84
            i am building an exact setup as yours, conquest with 2028,ice 200 hv setup. would like to know what you find out to be the problem. maybe the 465 to large of a prop to start with on 10s?
            • Slvrbowtie
              • Jul 2011
              • 22
              Prop is to big you were spiking im sure over 300amps with that setup. i know i was with that same motor but using a fc 200amp esc. i would stay in the 55-58mm prop range
              • Jesse J
                scale FE racer
                • Aug 2008
                • 7116
                What batteries and configuration-1 or 2P?
                I am running a 462 prop On my AM XXX mono (same esc/motor) and just looked at logging; 100amp average with 150amp spikes.
                I'm running 10s2p nanotech 45-90c packs with total mah of 10,000.
                You may not be giving the esc enough juice.
                "Look good doin' it"
                See the fleet
                • RaceMechaniX
                  • Sep 2007
                  • 2821
                  You were probably over propped on that set-up. I was logging 240+ continously with a 2028 on 10S2P in a big gas boat and small props. If you melted the wire off the board you were pulling too much current.
                  TG
                  Tyler Garrard
                  NAMBA 639/IMPBA 20525
                  T-Hydro @ 142.94mph former WR
