castle hydra ice 240
  • LuckyDuc
    Team Ducati Racing
    • Dec 2008
    • 989
    Can someone post what the data charts look like from the hydra ICE?
    • pandianightcross
      • 44
      I trust castle products , in my fav RC truck that is what I run is a castle esc and motor. great performance and alot of customization. This is one of those times when actually spending alot means getting alot
      You broke what?!?!?
      • RaceMechaniX
        • Sep 2007
        • 2821
        Something like this.
        Tyler Garrard
        NAMBA 639/IMPBA 20525
        T-Hydro @ 142.94mph former WR
        • LuckyDuc
          Team Ducati Racing
          • Dec 2008
          • 989
          Thanks for sharing! Is there a summary for each variable somewhere? Like avg amps etc? Can you choose to display certain things instead of all at one time?
          • RaceMechaniX
            • Sep 2007
            • 2821
            Yes, it is on the bottom of the log page below the chart. However when I save the file as an image it cuts off the lower table. But yes, it shows the average, max and min for each stored variable.
            TG
            Tyler Garrard
            • Diesel6401
              Memento Vivere
              • 4204
              Just got mine today!
              Normally on setups higher then 4s I run a rx pack. But with this esc I see that I can adjust the bec voltage where I like it. My question is has anyone run this esc on 6s with the bec? Just curious.
              - Diesel's Youtube
              - Diesel's Fleet
              • T.S.Davis
                • 6220
                MEEE TOOOOO! BEC on 6s would be sweet if it was trustworthy.
                Noisy person
                • RaceMechaniX
                  • Sep 2007
                  • 2821
                  Yes, I ran mine on 8S with the BEC. No problems even using a 400 oz-in digital servo on steering however I did not get enough testing time on it to really make a definitive statement.
                  Tyler Garrard
                  • ScarabChris
                    • Oct 2010
                    • 752
                    I am about to install two of these in my 54" Fountain. Looking forwardt o all the features like data logging and reverse. I also like the way you can program the amount of reverse to give it.
                    Then again my Spektrum radio dose the same thing.
                    • LuckyDuc
                      Team Ducati Racing
                      • Dec 2008
                      • 989
                      Has anyone run one and compared the results to the results from an Eagle tree to see how they compare for the same boat/setup? I'm curious to see how OR if the results differ greatly. Also, any word on if CC plans to offer a GPS add-on in the future for getting speed readings?
                        • 8011
                        I have run the ICE100 on 6S extensively without problems, haven't tried 8S.
                        Comparing the ICE to the Eagletree should give different results, as I understand it the amp draw the ICE displays is calculated rather than measured directly. The differences should be slight, but I'd be surprised if the two devices gave identical results.
                        • RaceMechaniX
                          • Sep 2007
                          • 2821
                          #27
                          From what I understand of the units, Castle is measuring the voltage drop across the FETS and knowing their resistance calculating the current. I noticed in my testing that the amp draw was a little on the high side compared to a eagle tree with the current loop measurement.
                          Tyler
                          Tyler Garrard
                          • Diesel6401
                            Memento Vivere
                            • 4204
                            #28
                            GREAT... I will give it a try my servo is only 180oz torque digital. My castle 6.5mm bullets don't look like they will fit he 8 gauge wire easily. I may bump up to 8mm on the motor/esc and just keep the batt side 5.5mm. My 5.5mm are half shell so the 8 gauge won't be a issue on those. Any comments.
                            Hull is a 40" HK Vanquish
                            Motor is a CC1717
                            6s2p
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • detox
                              • Jun 2008
                              • 2318
                              #29
                              This new esc is rather large. Plan your next build carefully around it.
                              • Accordnut
                                • Jan 2011
                                • 19
                                #30
                                Can you get a measurement?
                                Originally posted by detox
                                This new esc is rather large. Plan yout next build carefully around it.
