wil the Turnigy Marine 180A handle a neu 1521 1y on 6s ?
  • video200
    • 837
    as the title day. wil it handle it or wil it melt down ?
    also been looking at the castle ice 200 and the Hifei Swordfish 240 but they are a little pricy in comparison.
    thank you for any input
    klaus
  • blackcat26
    High Speed Junkie
    • Sep 2009
    • 1598
    I would say you should be fine, I'm sure some will disagree. My dads thundercat31 is running that motor on an etti 150a and extra caps with no problems.
    FE BOATING: Less like a hobby and more like an addiction!
    • Doug Smock
      Moderator
      • 5272
      klaus
      It depends the size, type of hull and the prop.
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • Make-a-Wake
        FE Rules!
        • 5557
        It should handle it just fine................notwithstanding severe overpropping.
        • video200
          • 837
          DF 33 cyber. prop. range X series 440/3,640,642 and 645. M series 440,545 and 645.
          heard alot of good things about the turnigy. but im a little worryed about taking it to the max on volts\amp.
          klaus
          • Make-a-Wake
            FE Rules!
            • 5557
            You should have no trouble running the 180a with the DF 33 and props mentioned.
            I run a 1527 1Y on 6s with the Turnigy 180a in a 45" mono...............runs cool.
            • video200
              • 837
              cool. gona order one then :) was looking at the castle ice. but for the price of the turnigy it just cant be beaten.
              • sailr
                • Nov 2007
                • 6927
                I'll let you know after Sunday. Will be using one in an Aeromarine Sprintcat 40 with NEU 1527/1Y on 6S and X447/3 prop. Wish me luck!!
                Mini Cat Racing USA
                www.minicatracingusa.com
                • video200
                  • 837
                  good luck sailr :)
                  but wont a 152 1y pull WAY less amps then a 1521 1y on the same voltage ?
                  im looking at the FEcalc and it keeps telling me that the 1527 wil draw less ( about half) then what the 1521 wil. i know that FEcalc is not a accurate tool, but it should give a small indicator i think ( might be wrong)
                  • Doug Smock
                    Moderator
                    • 5272
                    The 1521 1 Y is alot of motor for a 33" mono on 6s. You are going to have to pin it down to keep it on the water. You may have to add up to a lb. of lead. Watch your temps.
                    It's going to scream when you get her dialed in.
                    The 21 and the 27 are apples and oranges.
                    Good luck
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • sailr
                      • Nov 2007
                      • 6927
                      Could be right! Everyone says the 1527/1Y doesn't pull much on 6S.
                      good luck sailr :)
                      Mini Cat Racing USA
                      • sailr
                        • Nov 2007
                        • 6927
                        I run a 1515/1Y in my DF 33 and it's all I can do to keep it on the water! I've got all the speed I can handle for oval racing but may be different if running SAWS? Doug, you're the expert on that end of it!
                        Good luck
                        Mini Cat Racing USA
                        • video200
                          • 837
                          the plan was to run the DF on 4 and 6S and just swap the prop`s
                          if i can keep it at around 50 mph on 6S with a 440 or 640 i wil be more then happy. i dont have water for oval here only sport\SAW but it would be fun to take it to the local club and race a little on 4S :)
                          • Doug Smock
                            Moderator
                            • 5272
                            You got to love the 1515 1Y on 4s in a 30ish" mono!!
                            You may not believe this but my Rico ended up weighing 10 lbs 5 oz. ready for race water and a bit of wind.
                            Doug
                            MODEL BOAT RACER
                            IMPBA President
                            IMPBA 19887L CD
                            NAMBA 1169
                            • Make-a-Wake
                              FE Rules!
                              • 5557
                              A 1515 1.5Y on 6s would be a sweet combo in that boat IMO.
