Its just a simple instruction manual with all the settings. You simply set by pulling the throttle trigger at particular times............1-4 beeps chooses the setting you want to control.........LVC, Cells, timing, and Running mode............... and then the next step is to select your chosen parameter for that setting..................i.e. 2.8v, 3.0v,3.2v etc........ for cutoff as an example.
Turnigy vs aquastar
NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Its just a simple instruction manual with all the settings. You simply set by pulling the throttle trigger at particular times............1-4 beeps chooses the setting you want to control.........LVC, Cells, timing, and Running mode............... and then the next step is to select your chosen parameter for that setting..................i.e. 2.8v, 3.0v,3.2v etc........ for cutoff as an example.Comment
I dont care for the beep deal either, but this one is very clear and easy to do..............heck, even i can do it!! I've darn near memorized the setiings............NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
HAHAHA cool. When my esc fried I think the bec took a crap first then it smoked my rx. After the esc dried I tried pluggin it in to my program box and see if anything would happen and the box wouldn't turn on then the esc started smoking. You think the box is still ok seeing it didn't turn on? The only reason I would by another aquastar is cuz I have the box, but if it doesn't work their no reason for me to buy another one and I would swith to the marine.Comment
Fqdawld has had three marines dump on him, two on plug in. I've had a castle dump on me. I also had a mystery dump. Bottom line is no one brand will be smoke free. Choose a straw and hopefully your ain't the short one.
BTW the turnigy/seakng marine works with the handheld box that HK recommend. You just need to download and print the marine face plate as it come with a different one.If all of your wishes are granted, many of your dreams will be destroyed!Comment
Is this the what you mean for the marine? http://www.hobbycity.com/hobbyking/s...idProduct=7187Comment
Yep. I have only bech tested my aquastar on the bench. It's actually back ups for my Hydras. They are nice though.If all of your wishes are granted, many of your dreams will be destroyed!Comment
pot luck some times, i have had good runs with mystery 200a but hear some guys blow on programing.
i brought a mystery 100 amp a couple of weeks ago for $24 Aus shipped to my door in 6 days from hong Kong.
its in my vs1,i added a cooling plate of a turnigy 120
its set at 15 deg timing for my scorpion out runner,have been prop testing so only short runs,last test was with a x642 and after just over a minute run time the caps on the esc were just under 40c (100f) and it was a 30c day.
not bad for a esc that cost me (minus shipping) less than $10 AusComment
I have a Aquastar 120 and I'm having problems just getting Tx( Spektrum, Futaba, or Tactic) to calibrate. I trying to run 2s lipo with Chilli Pepper 4400 kv motor., The Spektrum and Tactic had to recalibrate every time I turned it on. The old Futaba had to turn throttle trim down, turn it back up to get full speed.. Then the next problem started, cuts out after a couple secs running in the water, seems to run ok on bench.. I've attempted to reprogram with tx with no luck. Been trying different things off & on for a couple weeks.
All help would be greatly appreciated.. Thanks AlComment
sounds like you need a programing box, it probably comes standard that low voltage cut off is for 3-4s. when your trying to arm it its seeing to lower voltage, this would also make it cut out under load in the waterComment
All help would be greatly appreciated.. Thanks AlFE BOATING: Less like a hobby and more like an addiction!Comment
Just back from the pond. I calibrated ESC to Futaba, it seemed to work I thought I had programmed, with TX, the cut off to 6v. Run good on bench, but still cuts out in water.
Aquastar for sale cheap..I'll see what HK says first.
Thanks for the Help AlComment
I for one would get a program box or USB adapter and make sure your setting are correct. When you calibrate your esc let the throttle go during the four beeps instead of after. If not it will go into program mode and you will end up changing the lvc. I accadently did that and set mines to a different parameter which is probably letting your lvc kick in. Hence the cutting out.If all of your wishes are granted, many of your dreams will be destroyed!Comment
I had a similar problem with mine, I have the USB linker. After calibrating the throttle, I plugged it in the PC and after that everything was ok. I have two runs on it, with a Feigao 12L on 4S, 46mm prop and it is barely warm when the cutoff kicks in. Love it (for now)...Comment
