Turnigy vs aquastar
  • Make-a-Wake
    FE Rules!
    • 5557
    Originally posted by Diesel6401
    What do you use to program the marine?
    Its just a simple instruction manual with all the settings. You simply set by pulling the throttle trigger at particular times............1-4 beeps chooses the setting you want to control.........LVC, Cells, timing, and Running mode............... and then the next step is to select your chosen parameter for that setting..................i.e. 2.8v, 3.0v,3.2v etc........ for cutoff as an example.
    • Diesel6401
      Memento Vivere
      • 4204
      I always go crazy listening for beeps lol, my A.D.D acts up... Curious if their was a card/box that works with it. I like the fact it has a higherburst rate than the aquastars.
      - Diesel's Youtube
      - Diesel's Fleet
      • Make-a-Wake
        FE Rules!
        • 5557
        I dont care for the beep deal either, but this one is very clear and easy to do..............heck, even i can do it!! I've darn near memorized the setiings............
        • Diesel6401
          Memento Vivere
          • 4204
          HAHAHA cool. When my esc fried I think the bec took a crap first then it smoked my rx. After the esc dried I tried pluggin it in to my program box and see if anything would happen and the box wouldn't turn on then the esc started smoking. You think the box is still ok seeing it didn't turn on? The only reason I would by another aquastar is cuz I have the box, but if it doesn't work their no reason for me to buy another one and I would swith to the marine.
          - Diesel's Youtube
          - Diesel's Fleet
          • BakedMopar
            No Mo Slipah
            • Sep 2009
            • 1679
            Fqdawld has had three marines dump on him, two on plug in. I've had a castle dump on me. I also had a mystery dump. Bottom line is no one brand will be smoke free. Choose a straw and hopefully your ain't the short one.
            BTW the turnigy/seakng marine works with the handheld box that HK recommend. You just need to download and print the marine face plate as it come with a different one.
            • Diesel6401
              Memento Vivere
              • 4204
              I had good luck with my aquastar until the crash, like I said I just hope I didn't blow the program box seeing that HC is out of stock. Steve has a box for the swordfish which is a hifei, that's why I was curious if it would work with a aquastar seeing the esc seem the same and the swordfish box seems identical to my aquastar box.
              Is this the what you mean for the marine? http://www.hobbycity.com/hobbyking/s...idProduct=7187
              - Diesel's Youtube
              - Diesel's Fleet
              • BakedMopar
                No Mo Slipah
                • Sep 2009
                • 1679
                Yep. I have only bech tested my aquastar on the bench. It's actually back ups for my Hydras. They are nice though.
                • ozzie-crawl
                  • Sep 2008
                  • 2865
                  #23
                  pot luck some times, i have had good runs with mystery 200a but hear some guys blow on programing.
                  i brought a mystery 100 amp a couple of weeks ago for $24 Aus shipped to my door in 6 days from hong Kong.
                  its in my vs1,i added a cooling plate of a turnigy 120
                  its set at 15 deg timing for my scorpion out runner,have been prop testing so only short runs,last test was with a x642 and after just over a minute run time the caps on the esc were just under 40c (100f) and it was a 30c day.
                  not bad for a esc that cost me (minus shipping) less than $10 Aus
                  • Flazip
                    • Dec 2009
                    • 4
                    #24
                    I have a Aquastar 120 and I'm having problems just getting Tx( Spektrum, Futaba, or Tactic) to calibrate. I trying to run 2s lipo with Chilli Pepper 4400 kv motor., The Spektrum and Tactic had to recalibrate every time I turned it on. The old Futaba had to turn throttle trim down, turn it back up to get full speed.. Then the next problem started, cuts out after a couple secs running in the water, seems to run ok on bench.. I've attempted to reprogram with tx with no luck. Been trying different things off & on for a couple weeks.
                    All help would be greatly appreciated.. Thanks Al
                    • ozzie-crawl
                      • Sep 2008
                      • 2865
                      #25
                      sounds like you need a programing box, it probably comes standard that low voltage cut off is for 3-4s. when your trying to arm it its seeing to lower voltage, this would also make it cut out under load in the water
                      • blackcat26
                        High Speed Junkie
                        • Sep 2009
                        • 1598
                        #26
                        My aquastar's seem to like to be calibrated upon startup also. I have to plug battery in then hold full throttle until after the three fast musical beeps then I release somewhere around after the 3rd or 4th slow beeps. From my experience you only need to do this once with an esc once but these seem to wanna go into program mode if you dont do it every time. I have a Turnigy k-force 150a esc that I like much better. Plug em in and run er! She has been soaking wet 2 or 3 times and is still ticking.
                        FE BOATING: Less like a hobby and more like an addiction!
                        • Flazip
                          • Dec 2009
                          • 4
                          #27
                          Just back from the pond. I calibrated ESC to Futaba, it seemed to work I thought I had programmed, with TX, the cut off to 6v. Run good on bench, but still cuts out in water.
                          Aquastar for sale cheap..I'll see what HK says first.
                          Thanks for the Help Al
                          • m4a1usr
                            Fast Electric Addict
                            • 2038
                            #28
                            Get a PiStix adapter and try it. I bet all of the problems go away.
                            John
                            Change is the one Constant
                            • BakedMopar
                              No Mo Slipah
                              • Sep 2009
                              • 1679
                              #29
                              I for one would get a program box or USB adapter and make sure your setting are correct. When you calibrate your esc let the throttle go during the four beeps instead of after. If not it will go into program mode and you will end up changing the lvc. I accadently did that and set mines to a different parameter which is probably letting your lvc kick in. Hence the cutting out.
                              • CornelP
                                • May 2009
                                • 745
                                #30
                                I had a similar problem with mine, I have the USB linker. After calibrating the throttle, I plugged it in the PC and after that everything was ok. I have two runs on it, with a Feigao 12L on 4S, 46mm prop and it is barely warm when the cutoff kicks in. Love it (for now)...
