being a black wire and it looks like its on the negative side i would think you maybe just solder it in with the negative bullet but iam no expert
that can be the problem with some of the Chinese gear, no instructions
Actually, yes, it is a spark control resistor. You are right, it will precharge, so you have to connect the wire with the resistor before connecting the main cable. See:
This will save your esc caps from ending too soon..
I just put a 33 ohm resistor in between aligator clips so I can use it on any esc.
I will use this for all my 4S+ boats this year.
Ray would it be possible to post a picture of this resistor? The aligator clips are soldered to the resistor, then connect them to the positive bullets (esc+bat) then disonnect them and connect the bullets? How you do that?Thanks...
