Spektrum radio / Hydra 120 compatible ?
  • cacofonix
    • Jul 2008
    • 240
    you mean in esc menu ?
    • JimClark
      • 5907
      No the radio
      Billy Graham
      • JimClark
        • 5907
        yes there is an end point adjustment and a travel adjust both effect the throttle.
        It has been a while since I programmed my DX2 but I think there are two functions that could alter the throttle
        Jim
        Billy Graham
        • cacofonix
          • Jul 2008
          • 240
          sorry but in DX3R menu there is only one menu : TRAVEL
          and i set throttle / brake to 130%
          no other menu
          herve
          • JimClark
            • 5907
            Sorry I didn't see the R I have just the DX3
            Billy Graham
            • JimClark
              • 5907
              maybe you might try playing with the trim step feature
              I should get one of these looks easier to set um than my DX3
              Billy Graham
              • nutz1207
                • Jul 2009
                • 19
                i to am having the same problem but i have a dx3s. and i have tried to adjust the trim and the travel and it still blinks when at full throttle. so i called castle and the guy i talked to said that its fine. i did not get his name though.
                • LiPo Power
                  DJI Drone Advanced Pilot
                  • May 2009
                  • 3186
                  #23
                  You guys with the set up problems should contact HappyOne
                  He is using the same radio now with Castle ESC and I saw him reprograming, calibrating his CC ESC with no problem, ask him please.
                  Robert
                  Canada
                  • JimClark
                    • 5907
                    #24
                    Darin also has the 3S so contact him also
                    Billy Graham
                    • cacofonix
                      • Jul 2008
                      • 240
                      #25
                      great !!!
                      did they often came on this forum ??
                      • Jimmy Sterling
                        • Apr 2008
                        • 393
                        #26
                        I have been using a DX3S radio system in all my boats that have CC ESC's setup in them and had no issues what so ever with calibrating WOT.
                        However, I am still using the older firmware (1.03 I think), that is obviosly where the problem lies
                        The 3S has two functions within the radio that allow for travel and trim + the normal throttle trim operation to be modified.
                        Before calibrating the ESC be sure that the trim control located to the left of the wheel is set to 0 on the main LCD menu, the sub trim is set to 0 and that the travel option within the radio's menu is set to 150 %.
                        I have performed this many times with no problems
                        BTW, why go to the new firmware in the first place ?
                        Jimmy
                        Come to the FASST side
                        • Team FFRB
                          • 328
                          #27
                          C/C
                          Jimmy,
                          You are right!
                          "BTW, why go to the new firmware in the first place ?"
                          I wonder if Joe Ford has had his team fix firm ware 1.04 yet? If not, Why not?
                          HOT RODS ON WATER
                          • Jimmy Sterling
                            • Apr 2008
                            • 393
                            #28
                            No use trying to fix something thats not broken
                            • cacofonix
                              • Jul 2008
                              • 240
                              #29
                              hi folks
                              i upgrade firmware because i use mega motors that have 6 magnets
                              and i read that 1.03 version have problem with timing ......
                              i don't know if i can dowgrade to 1.03 ......
                              ok jimmy, i will check sub trim, but yesterday i already try with 150%
                              herve
                              • Raydee
                                • May 2007
                                • 1603
                                #30
                                I have calibrated my DX3R to a bunch of CC controllers with the throttle travel at 100% without a issue. It sounds like the ESC is the problem. Like others have suggested try downgrading the firmware to 1.03 and see if it will calibrate correctly.
                                Team Liquid Dash
