24 volt power supply
  • T.S.Davis
    • 6221
    Does anyone know of a rock solid 24v supply? I mean that can deliver 75+ amps reliably?
    I have the kind made of two pc supplies wired in series from two suppliers and they can't hang. Fail. Glad I kept my Rivergates. Always work every time but I have to drop down to nothing for charge rates. When you're charging 8 boats per round it's taxing.
    Is there anything out there that is truly designed to push 24 volts under load?
    The Revo looks good but still only 55amps.
    Noisy person
  • photohoward1
    • 1610
    What about the BullDog Power Supplies. http://www.rivergatedist.com/bulldog_90.htm
    I have the ddc-75amp 12-14v....The only limiting factor is my Invertor/Generator. I am going to upgrade that to this:
    Find out which Yamaha is right for you. Find A Local Dealer Today, View Inventory, Get Prices & More. Models: R7, MT-07, Tenere 700, MT-03, YZ250F.
    • Doby
      KANADA RULES!
      • 7280
      Terry...talk to Robert (LiPo Power) ...he sells some really good HV power supplies.
      He could probably deliver it to the Can Am.
      Grand River Marine Modellers
      • T.S.Davis
        • 6221
        John, that's one of the failed supplies.
        I have two bulldogs. Great for 12 volts. Super reliable. Of you want some big power they can't keep up at only 12 volts.
        Noisy person
        • ray schrauwen
          • 9471
          I remember Pete Steinke had a nice power supply he used to charge directly to hid Dewalt A123s at 30 amps. It had separate voltage and current adjustment. Like a 50v 50amp or more lab type PS...
          Just found this... http://www.trcelectronics.com/View/M...-2400-24.shtml
          • TRUCKPULL
            • 2971
            Ray
            That requires 240 Volt input
            That would need a big generator to supply it.
            Larry
            • TRUCKPULL
              • 2971
              Here is one that only needs 120Volt input.
              Shop for the Mean Well RSP-2000-24 power supply from TRC. We offer free technical support, discounts and accurate stock info so you can buy with confidence. Order yours now to get fast shipping!
              and a little less money
              Larry
              • Tuono995
                • Dec 2017
                • 24
                Hey anyone have any feedback on Meanwell 24v power supplies or Weho which look the same as Meanwell....?
                • RaceMechaniX
                  • Sep 2007
                  • 2821
                  I use Mean Well and Lambda power supplies for my charging. Mean Well are great middle grade power supplies, but are not cheap for the hobbyist compared to the recycled server power supplies.
                  Here is the one I use for 24V charging: https://www.alliedelec.com/mean-well...0-24/70069586/
                  Great power supply if you are willing to invest in quality.
                  If you need more than 60A, I would suggest you get two smaller ones.
                  Unless you have a 220V plug on your generator and you better if you are trying to charge over 2000W.
                  Here is the 80A@24V power supply: https://www.alliedelec.com/mean-well...0-24/70231561/
                  Tyler Garrard
                  NAMBA 639/IMPBA 20525
                  T-Hydro @ 142.94mph former WR
                  • TRUCKPULL
                    • 2971
                    Tyler
                    Both of those units you mentioned above, require 200 volt input.
                    Larry
                    • photohoward1
                      • 1610
                      TYLER. What is a good power supply for 120vac input and 24v output?
                      • dethow
                        Wired Racing
                        • Oct 2014
                        • 1500
                        This MIGHT (???) work for you Terry. Not a bad price at $135. Maybe run 2 of these?
                        I personally just switched over to this 12v supply. I'm very pleased.
                        Just thought I'd share for those that don't need as much power as Terry is looking for.
                        Have fun with that....
                        • TRUCKPULL
                          • 2971
                          https://www.ebay.com/itm/HobbyStar-C...53.m2749.l2649
                          Dave
                          Those are both Server Power supplies also.
                          Terry already tried them, with NO luck.
                          I know that I have been running the 24V-75A HP supplies for a few years with No problems at all.
                          Larry
                          • pescador
                            • May 2009
                            • 499
                            There are the 24 volt Meanwell's but still only 63 amps.
                            Very powerful power supply provides 1500 watts, 62 amps, 24 volts, with active power factor correction
                            I use two of the 42 amp versions for my PL8's.
                            Namba District 16
                            • RaceMechaniX
                              • Sep 2007
                              • 2821
                              Howard and Larry, the Mean Well RSP-1500-24 is one of the best power supplies and is available with 120V input. Pescador has a link to Progressive RC’s site.
                              Tyler Garrard
