Lipos puffing on a conservative setup, what gives
  • 785boats
    Wet Track Racing
    • Nov 2008
    • 3169
    Originally posted by Skullcracken
    This was definitely a longer run, 5 min. But mid speed, a few fast passes. But this thing has baked 2 lipos in about 2 minutes before. Perhaps 2 3s in series is no bueno?
    Just as a comparison, I run that same motor in a 36" mono spinning an X447/3 blade prop.
    A race including a mill lap lasts about 1:40sec.
    A pair of 3s 5800mah 60c packs are down to about 25-30 percent at the end of the race.
    So a pair of 5000 40C packs must be hurting after more than 2 minutes. Especially if there is a lot of stopping & starting, or if the hull is running wet.
    • grsboats
      • Jul 2012
      • 975
      Many Turnigy batts puff in normal conditions BUT 5 minutes running can kill very shortly a batt.Anyway check the inside of your batt and see if it is a 5.0A.....I had a similar issue with a Turnigy pack and figured out that that junk batt was only 4,5A...there is an old thread about this. Gill
      GO FAST AND TURN RIGHT !
      www.grsboats.com.br
      • Doby
        KANADA RULES!
        • 7280
        Originally posted by Doby
        You should be running 6S2P
        Best advice ever.
        Grand River Marine Modellers
          Best advice ever.
          Bingo
          • 785boats
            Wet Track Racing
            • Nov 2008
            • 3169
            It would be nice to have that option for racing here in Australia, but we are only allowed to run 1p and with a total weight of 950 grams for the 6s pack. And 650 grams for a 4s1p pack. So that limits prop size for us if we don't want to destroy batteries.
            But yes, for a sport boat 6s2p would be the way to go. Or drop the kv rating down to 1250kv, or so, for less current draw.
              Agh...well you have a good point then. So maybe go down on kv a little like previously recommended.
              • JohnZ
                • May 2010
                • 254
                There are some complaints about the new Hyperion packs puffing prematurely under normal use. I have read a number of threads over at RC Groups complaining about the new Hyperion G6 HV packs. I have one of these in my stock and only have a couple cycles through it so far, not even down to minimum yet so I'll have to keep an eye on it as i continue to break the pack in.
