Lipos puffing on a conservative setup, what gives
  • Skullcracken
    • May 2010
    • 617
    I have a Dr pirate 35 inch, with a typical setup, 4082 1600kv on 6s. Using an x445 prop. Runs great seems effortless, but last two outings puffed two turnigy 3s 5000 40c lipos severely, enough to split the blue casing. Ran again with two new turnigy's 3s 5000 4pc lipos, one looked brand new, the other was puffed out, and the label peeled up from the heat. Ruined. Any reason this is happenening on a moderate setup? I see guys run 4082 2200kv on 6s and I'm running a 1600kv...
  • 785boats
    Wet Track Racing
    • Nov 2008
    • 3169
    I would venture a guess & say that you are running the batteries down too far by running for too long.
    What were the cell voltages after the run?
      I'm not so sure how 'moderate' that setup is, IMO too high a Kv and too small of a prop to be optimum for a boat that size. Be that as it may, Paul's assessment could be good too. What ESC?
      • Jamey
        • Apr 2015
        • 199
        785boats is onto the right track! I would guess max wot run time should only be about 2 minutes tops, maybe less?
        Maybe it is just me but I personally don't call 1600kv on 6s as conservative especially in a mono. Granted it isn't a super hot saw set up of course but it is far from being "conservative". If the boat is running wet it will draw some decent amps. Think ~1250kv as conservative. That boat has enough room for 6s2p, you might look into doing that. 8000 to 10,000 mah total will definitely help run time and battery life.
        • StevenBryant
          • Nov 2012
          • 359
          I run a very similar setup with turnigy 5000mah cells on a M445 or M545 and have never had problems with the cells, I personally think you have been running the cells down too low or you have problem with your motor.
          • JimClark
            • 5907
            So then what is your runtime?
            Billy Graham
              • 9488
              Did you measure your cell voltages after they rested some ?
              • Skullcracken
                • May 2010
                • 617
                This was definitely a longer run, 5 min. But mid speed, a few fast passes. But this thing has baked 2 lipos in about 2 minutes before. Perhaps 2 3s in series is no bueno?
                • Skullcracken
                  • May 2010
                  • 617
                  Meant to refer to it as a moderate setup. But I've seen guys run 6s on 2200kv which I think is way too much, but I end up the one baking bread in the battery trays.
                  • Skullcracken
                    • May 2010
                    • 617
                    Turnigy 180amp
                    • Skullcracken
                      • May 2010
                      • 617
                      Maybe too long of a run. On the charger was down to 11.34v to start new charge on the non damaged lipo
                      • Tamelesstgr
                        • Jun 2014
                        • 1516
                        Those 40C packs can support 200 amps with the 5000mah rating. I will be running the Leopard 4082 with 1450kv on 6s, I will be ordering 60c packs from Revolectric. Is your motor a Leopard 4082 or another brand? Any specs on the motor wattage, max amp draw, etc?
                        NEVER SATISFIED RACING
                        Fine Design 32 V-Hull 4082+6s
                          • 9488
                          there is your answer
                          • NativePaul
                            Greased Weasel
                            • 2761
                            Running 2x 3s packs in series as a 6s pack does work, plenty of people do it. what connectors do you use, it is possible that too small a connector is heating the wire and the tabs up too much. If that 11.35v is for a single 3s pack, not a surviving pair in series for 6s then that is near 3.8v/cell or about half full, so it wasn't overdischarged, did the pair start off at the same state of charge? Did you use the same charger for both? Were they a matching batteries of the same capacity and C rate? If so the other wont have been overdischarged either. All that is left is that it was pulling to many amps, is your drivetrain free and well lubricated during a run? Do the motor bearings feel OK? Is the boat running loose or wet? Where is your prop in relation to the hull bottom? How sharp is the prop?
                            • Doby
                              KANADA RULES!
                              • 7280
                              You should be running 6S2P
                              Grand River Marine Modellers
