Revolectrix
    I already know what the outcome will be.......
    • Doug Smock
      Moderator
      • 5272
      #77
      Originally posted by madmikepags
      I have batteries that are close to 5 years old with hundreds of cycles and most packs still are under 2milliohm per cell IR and balance out perfectly, especially my hyperion 5000's and 6500's
      That's typical of the Hyperions. How's the IR looking on your Revos fellas? Mine started life at 4m and continued to rise. Last charge cycle the measured 7m.
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
        I meant to reply to his post. That's impressive. ...very impressive!
        • oscarel
          • Dec 2009
          • 2128
          #79
          I have 4 HV 5s 4200's and they're in the 1.5milliohm range after about 20 cycles. Rising IR isn't a good thing is it???
          • boatbandit2
            • Jun 2011
            • 98
            #80
            Will these HV batteries work with the hobbywing 180 amp ESC or is a HV esc required?
              Yes they will work
                What name brand?
                • Doug Smock
                  Moderator
                  • 5272
                  #83
                  No sir.
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                  • keithbradley
                    • 3663
                    #84
                    What are you measuring with Doug?
                    IR readings are not completely synonymous with higher quality, but those readings seem to be off by a lot either way. Mine are all sub 2mO unless they're cold. What do your other lipos test at?
                    Are these the 70C packs?
                    www.keithbradleyboats.com
                    • oscarel
                      • Dec 2009
                      • 2128
                      #85
                      Should still be safe for 6S and below.
                      • oscarel
                        • Dec 2009
                        • 2128
                        #86
                        Originally posted by kfxguy
                        What name brand?
                        Revolectrix
                        • Peter A
                          • Sep 2012
                          • 1487
                          #87
                          My old thrashed turnigy blue packs are reading 7 mO. They also suffer badly from voltage drops triggering lvc, hence getting new revo's. I just have to go through the disposal process with the turnigys now.
                          • boatbandit2
                            • Jun 2011
                            • 98
                            #88
                            Yes they will work
                            thanks I will order some for my apparition, well done on 95.6 mph I have a goal to reach now.
                            • Doug Smock
                              Moderator
                              • 5272
                              #89
                              I'm using Hyperion 615s and 720s
                              I don't disagree that IR readings are not completely synonymous with higher quality.
                              I'm also certain that stated high capacity cells with high IR are worthless in high power set ups. As worthless as low IR cells lacking capacity. It doesn't matter what the capacity is if you can't deliver it.
                              The vast majority of my batteries are Hyperion. As Mike stated 100s of cycles over several years and low IRs. Under 2m.
                              2,3,4,5s packs 5-5500 35c and 5-6500 45c. Should have never swayed but whatever.
                              LNE 6000 65c, and the Revo 5000 70c? (Who really knows right? I don't believe that was ever cleared up.)
                              The IR on the LNEs according to my equipment started around 3m and are upwards of 8m now IIRC.
                              6-6000 65c, 2 with 8ga wire. 2 that I removed approx. 14" of wire from. Also have two 4s 5000s. One is trying to puff.
                              The Revos started at 3m and measured 7m at last charge cycle.
                              All of these packs are less than 6 months old and have less than 50 cycles on them.
                              I'm sure they are both great batteries. I just got some out of a less that stellar lot. It happens and I'm sure someone has similar Hyperion stories.
                              FWIW
                              DuhG
                              MODEL BOAT RACER
                              IMPBA President
                              IMPBA 19887L CD
                              NAMBA 1169
                              • oscarel
                                • Dec 2009
                                • 2128
                                #90
                                FWIW
                                DuhG
                                Contact John at Revo if you don't think the packs are holding up, the HV packs do have a warranty .
