14.8v lipo ?
  • jerry123
    • Feb 2014
    • 75
    14.8v lipo ?
    I was wondering if my boat calls for a 14.8v 4s 30c 4000mah lipo. with motor bl3660 kv2400 motor and 100 amp esc. In a 26" hydro.
    Do you think I could run a hotter battery without damaging motor and esc?
    Would it be better to run 1 4s 30c 14.8 battery or 2 2s 7.4 batteries seriesl?
    Thanks Jerry
    A "hotter" battery? Do you mean higher voltage i.e. 5S? Not recommend as it will probably damage the ESC. One pack or two depends on the room inside the hull. Pics might help..
    • Alexgar
      • Aug 2009
      • 3534
      I believe there recommended battery is the minimum battery that should be used
        Would it be better to run 1 4s 30c 14.8 battery or 2 2s 7.4 batteries parallel?
        Sorry, I missed this the first time. If you run two 7.4 volt pack in parallel the boat will only go half speed. You need to wire them in series.
        • lenny
          • Sep 2010
          • 4294
          Hear some info you should read and learn,
          Before something bad happens.
          Lots of good info in this link.
          Thanks Jerry
          ? ONLY IF THEY WORK
