I have a pair of soft case lipos that we're submerged in fresh water over night. Their apperance seems fine. No swelling and look normal. They have dried for about 5 days. I'm about to try and charge them for first time. Anything I should do special? Thx Jeff
Wet lipos
What do the cells read with a cell checker ? -
Look carefully at the balacing tabs, even fresh water will put greenish corrosion, you need to use a tooth brush with WD-40 to clean. I had a pair under water for only 30 minutes and was like that already. If it isn't cleaned, may give false reading and incorrect balancing.Too many boats, not enough time...
Those reading do not look very good,
And most lipo charger will not work with the cells that low.
You could try and charge them on a very slow NiMH charge with the cell checker on them,
And watch that they do not start to get hot and the volts do not go over 3.85 for each cell.
Than if they take that NiMH charge and do not get hot,
You can try and do a lipo charge on them.Comment
Jlov.
Is that a typo? In the first pack you say that the No 1 cell is at 7.03V.
Please tell me that you meant 3.03V.
Paul.See the danger. THEN DO IT ANYWAY!!!
Charge them out on your driveway. That's what I do for looks in question. Catch fire....well at least nothing will be around it.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I didn't hurt mine. It would go into protect mode when I had it set for lipo. I put it on NiMH on a VERY low amp setting and let it bump them to minimum voltage. I think it was on .1 or .2 amps.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
It's just that a single cell can't be at 7.15V . I can't figure out how it can be that high & not have exploded. It must be a false reading somehow. Or perhaps the negative balance wire has come off & it is reading the full pack voltage.
The cells themselves can't be damaged by being under water. Only the connections. They will eventually corrode & the balance wires break off.
The ends of the packs need to be opened up & all the connections completely dried out after a dunking.
I have opened up many packs to re solder wires & tabs, remove blown cells, or replace puffy cells. Both for myself & fellow club members.
***But if you are not confident in cutting open a pack, I would advise you not to try it.***
That reminds me. I have a mates 6s pack that has a dead cell & needs to be re configured to a 4s pack. Must get to it.
Cheers.
? ONLY IF THEY WORK
when I plug them into charger. Lol Thx Jeff
