Wet lipos
  • Jlov
    • Nov 2013
    • 825
    I am sure I can accomplish it if I know what to do. So I cut off shrink wrap from battery and re-solder the balance wire and the positive and negative wire? I use a mini torch to solder my bullets. Guess to solder this I would use a soldering iron? Thx Jeff
    • 785boats
      Wet Track Racing
      • Nov 2008
      • 3169
      Firstly.
      If you have a digital multimeter check the voltages of each cell at the balance plug. A dead cell will sometimes give false readings with cell checkers. Maybe one cell is dead.
      • Jlov
        • Nov 2013
        • 825
        Do not have a digital multimeter. The batteries were working fine before plunking and had only been charged 5 times as I had just bought them. Could a soaking make a cell go bad? Thx Jeff
        • 785boats
          Wet Track Racing
          • Nov 2008
          • 3169
          I would say that cell has totally discharged while under water. Perhaps a low resistance short at the balance plug, from something in the water, or in the connections at the pack.
          If you do open the pack, you will need a multimeter to check each cell to find the problem. But it will be a throw away pack if it is a dead cell.
          When I check a pack, I only carefully cut open the end first, just in case it is fixable at the connections. See the pics. That way I don't have to re shrink the whole thing. Just a couple of strips of deck tape to reseal it.
          If the pack needs a cell removed or replaced, then I open up the whole pack.
          • Jlov
            • Nov 2013
            • 825
            I waited a week and then tried to charge these today. The one with the funny numbers wouldn't take a charge. Scrap heap for it I guess. The other one seemed to take a full charge on my charger. Readings after it had charged are:
            No1 4.18
            No2 4.16
            All 8.23
            Is this lipo ok? Thx Jeff
            • lenny
              • Sep 2010
              • 4294
              You need to put a full load on it to find out,
              Looking a the readings it looks ok to test out.
              The other one you need a NiMH charger to maybe bring it back up slowly to the right volts.
              ? ONLY IF THEY WORK
