Storing My Hyperion problem
  • dasboata
    • Dec 2010
    • 3152
    Originally posted by kevinlew211
    what you can do is turning those balance wires to 6s1p by connecting the positive (red) balance wire of 2s to positive (red) of 4s connector and taking of 2 of negative balance (black) wires from 2s and putting them into the next 2 slot of your 4s balance connector, its simple easy and you dont have to deal with with 2s1p +4s1p balancing again.
    I was looking at what you were telling me to do 1 question. I need to purchase a 6s1P balancer connecter correct ? thanks chris
    • ray schrauwen
      • 9471
      This can be done as long as you always connect the main pack wires the same and correct way. Switch pos & negs and you will see sparks.
      As me how I know.
      • ray schrauwen
        • 9471
        Here you can get the 2S 4S combo connector: http://hyperion-world.com/products/type/18
        Scroll down to find the connector that suits your needs as hey have several connectors for different chargers etc...
        • ray schrauwen
          • 9471
          Here is the basic idea of how individual packs are wired. If you were to switch the balance connectors around it could cause a spark and possible damage. Likewise if you were to leave the balance connectors as they are and move a cell (disconnect) and place it in a different position you would need to re-wire the balance lead otherwise same spark or damage.
          In picture #1 in post #1 you have basically 2 packs heat shrink together. If you were to switch the main leads (that are connected in the picture, you have one set of pos+ and neg- connected) and connected the other pair then there is a problem with parks and your charger not liking the configuration.
          If it was me, I would get a 6S balance housing and put all connectors into it properly and hard wire the pair of leads connected in the picture but, maybe your balance leads are not long enough for that. In that case a 6S balance connector with leads on it could be used to splice the 2 balance connectors together. These are cheap I have some of THESE around if you need one or more. They sell some individually too.
          • ray schrauwen
            • 9471
            Originally posted by dasboata
            I am try to put this battery in storage mode., but when I tried the 2 cell it said open circuit the balancer jack only fits in the 4S slot any help is appreciated thanks chris
            Because Hyperion uses a different wire configuration they keep the large harness even for a 2S pack. It's done this way for certain type of goof proofing with their chargers. All you have to do is move the wires (one at a time) out of their slots and into the right slots that the 4S receptacle on the charger will accept. Problem solved. What charger are you using ? I bet it is not Hyperion.
            Now I got it. You are using adapters that are HXT config and you are using Hyperion packs. That is why it gives you the error message. You can reconfigure the wiring for the 2S pack so this works fine as I posted above.
            • ray schrauwen
              • 9471
              O.k. here we go. I grabbed my last pair of 7 yr old 2S Hyperion packs to show you how to reconfigure them so they do not error out using the connector boards you have.
              In the picture you will see a black lead in the top, a red lead at the bottom and another black lead just above the red, this leaves 2 slots open in the middle.
              If you take the black wire out of the plastic harness using a needle or something very thin to press down the spring tab it will pull out cleanly. Take that lead and insert it just below the top black wire, Now remove the red lead and insert it below the black wire you just moved.
              You can now balance it with the connector boards you have. You have basically reconfigured it to be in HXT mode or configuration. The 4S pack is done already.
              This is why I dislike Hyperion balance taps and really like HXT configuration.
              Again if you want to balance the 4S & 2S pack together you will need a 4S 2S connector BUT, if you buy it from Hyperion, do not do my reconfigure as it will error out again.
              I would stick with one configuration or the other.
              What charger are you using? If it's not Hyperion maybe reconfiguration is best but, I leave that up to you.
              Below is my just reconfigured Hyperion 2S pack in a HXT connector board.
              • dasboata
                • Dec 2010
                • 3152
                I do use a Hyperion charger Thanks for the help
                • kevinlew211
                  • Aug 2008
                  • 586
                  Chris,
                  I thought its already came with 6s balancer connector and just missing 2 black (negative) wire of cell number 5 and 6, if its not then yes, you have to buy a 6s balance connector, sorry for late respond.
                  • dasboata
                    • Dec 2010
                    • 3152
                    Hey Ray I am not going to mess with it I don't want to screw anything up I am going to look for the y connector thanks for all the help guys Chris
                    • ray schrauwen
                      • 9471
                      That's your best direction since you have Hyperion charger(s).
                      • dasboata
                        • Dec 2010
                        • 3152
                        I want to thank you guys for all your help here I especialy want to thank John Snider from Tork-it [email protected] Doug smock put me in touch with John after a few e mail John knew what I needed a few days later I received in my mail a y connector I hooked it up and it worked great , I owe John big time for taking the time to ask me all the right questions to get this right the 1st time thank you John Snider !
