Thanks eboat got the picture. I makes sense, I will give it a try and will let you know how it works.
Hot to Hotter Batteries
The props you have are all ok sizes. For longer runtimes try putting 2 packs in parallel (2P). Also try adjusting prop height/angle and COG to get the boat running at the right attitude. Don't get too hung up on the roostertail, although a long flat tail is what you want.NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
BOPMPBC Open Mono, Open Electric Champion.Comment
There realy isn't a hard formula for it. There are too many variables that affect current draw. The revolt needs 5000 ma packs. With the props you have this will give you a safe run under 5 mins. Just for the sake of using up the packs you have you could run two 4000ma packs in parallel to creat an 8000ma pack. You should be ok for 6-7 minutes.Comment
