Need some Help, Run time
  • JLShip
    • Jul 2013
    • 74
    New to sport, run time, for a stock REVOLT 30, prop x442 or M445 Racing ................. Battery,
    Dinogy 4S 5000 65C
    Normal Laps NAMBA 6, Off Shore( 4 min's)
    Your Help would be appreciated.
    RC Grandpa
    NAMBA Dist. 9
    Folsom R/C Modeleers
    The m445 will work fine for a one-mile oval heat race. Don't know about a 4 minute offshore heat.
    • siberianhusky
      • Dec 2009
      • 2187
      You might JUST make it, maybe, be hard on the batteries running them down to pretty much LVC every run, I get 3:30 and put just shy of 4000mah back in my packs. Offshore I'd run a pair of 4s packs in parralal about 4000mah each. I don't like running my batts down to LVC. I might make 4 minutes but not with mill laps and start countdown...
      • JLShip
        • Jul 2013
        • 74
        Newbe: FE Question , how do I run Parallel with my 4S
        RC Grandpa
        NAMBA Dist. 9
        • siberianhusky
          • Dec 2009
          • 2187
          Make up an adapter using the kind of connectors you have on your battery and esc to allow you to plug both red battery leads into the plus side of the esc and the same for the negative.
          Easier to describe if you tell what kind of connectors you have on everything.
          I standardized everything to 5.5mm bullets, motor, batteries and escs also my charger, makes it easy to swap stuff between boats for testing or after something blows up.
          The stock connectors are pretty much at their maximum, they can get really hot once you start pushing the boat harder. The esc rating is very conservative, I regularly put way more amperage through it than the company claims, thats when the stock connectors become the weak link.
