Wet lipo battery?
  • Andris Golts
    • Jan 2011
    • 504
    Wet lipo battery?
    Hi all my Turnigy 14.8v 5000mah lipo got wet i cut off the blue heat shrink wrap let it dry for 24 hrs and went to recharge on my Hyperion charger which i recharge at a charge rate of 5 amps and noticed max charge was .25 amp and took 3hrs to put back 1000 mah into the pack. Would i be correct to assume the lipo pack is finished and should be dissposed ? Regards Andris Golts.
  • JimClark
    • 5907
    it's going to take a very long time at .25 of an amp I would try it again at5 amps and see what it does.
    Billy Graham
      Was the water salty or brackish?
      • adam777
        • Oct 2012
        • 55
        Was it salt or fresh, fresh will be ok you need to thoroughly dry it and maybe a good soak in Methylated spirits,
        Salt water would need an immediate dunk in fresh water then the above treatment, but after 2 weeks the damage will be done.
        • Andris Golts
          • Jan 2011
          • 504
          The water was fresh water. Regards Andris Golts.
