Mean Machine v3 running a single 6s 5100mAh Pack?
  • sampit
    • Jul 2009
    • 447
    Would it be possible to build a good handling 6s mean machine v3 using a single 6s 5100mAH 6S Dinogy lipo running on the tunel floor or will this be a bad move?
    I realize that 2 x 3s lipos would be the better option, but i have a new single 6S packs i would like to use in my next build.
    FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
    Popeye Hydro T600 1400kv 6s1p
    I have run my MM with a single 4S pack on the tunnel and it runs great. Why do you say that two packs would be better?
    • sampit
      • Jul 2009
      • 447
      Thanks fluid. i just thought it would balance the hull beter, with one in each sponsons. maybe this is not the case with cats,
      • sampit
        • Jul 2009
        • 447
        I have two 4000mah 4s packs 35c and two single 6s 5100mAh Dinogy packs i could use and two spare motors Trackstar 4068 2550kv I could use for a 4s2p or 4s1p maybe this motor is a bit high on the kv, also have a TP 4082 1450kv for a 6s1p setup option. not sure what way to go.
        ps whats your MM?
        • Heaving Earth
          Banned
          • Jun 2012
          • 1877
          6s packs might be a tight fit in the sponsons.
          • sampit
            • Jul 2009
            • 447
            I was thinking may be just use one pack across the tunel floor, I agree two would be to big for a this hull
            just not sure if it would be ok to build just using one 6s pack, would it be hard setting the COG once a motor was fitted
            • Heaving Earth
              Banned
              • Jun 2012
              • 1877
              Well, I run two 5s in mine and it works very well
              • sampit
                • Jul 2009
                • 447
                What size mAh 5s packs are you running yours on
                Just to get an idea.
                • Heaving Earth
                  Banned
                  • Jun 2012
                  • 1877
