what battery would all of you recommend
  • novice
    • Mar 2013
    • 9
    hi all ,
    i am new to this rc group and new to the world of rc boats , i am busy building a mystic c5000 43" boat from ply and balsa wood and then going to skin it with carbon fibre.
    i have all the working parts for the boat.
    but i am not to sure of a battery or batteries for the motors and esc's i will be running in this boat.
    any help would be great fully appreciated , another question i have is would i plug both esc's into one receiver that i have.
    here is the list of parts i have , electronic and propulsion wise .
    2 X LEOPARD 4082-1250KV
    Model: LBP4082/2.5Y
    Max Amps: 82A
    Lipo Cell: 5-10s
    Max Power: 3500W
    KV(RPM/Volt): 1250
    Resistance: 0.0128
    No-load Current : 1.6A
    DiameterĂ—Length (mm): Φ39.8Ă—82
    Mounting hole depth: 7mm
    Length of extend Shaft : 20mm
    Shaft Diameter (mm): Φ5.0
    Weight: 485g
    2 X Turnigy marine 180A Brushless Boat ESC
    Constant Current: 180A
    Burst Current: 360A
    Resistance: .0007ohm
    Battery: 2-6S Lipoly
    BEC: 5.8v/ 3A
    Motor Type: Sensorless Brushless
    Size: 72 x 68 x 34mm
    Weight: 165g
    1 x spektrum 3000 marine receiver
    Type: 2.4GHz Marine Receiver
    of Channels: 3 (plus dual throttle and steering outputs)
    Modulation: Marine
    Band: 2.4GHz
    Dimensions (WxLxH):0.75 x 1.3 x 0.2 in (19 x 34 x 5mm)
    Weight: 0.2 oz (6 g)
    Voltage Range: 3.5-9.6V
    Antenna Length: 14 and 8 in
    1 x Spektrum S6040 High Speed Surface servo 12kg
    Dimensions (L x W x H) : 40 x 20 x 37mm
    Gear Material : Titanium
    Input Voltage : 4.8 - 6.0v
    Motor Type : Coreless
    Servo Speed (6v / 60 deg) : 0.08s / 60 deg @ 6.0v
    Servo Torque (6v) : 12Kg-cm (167 oz-in) @ 6.0v
    Weight : 52g
    thanking you
    NoViCe (clinton)
    • 7990
    You will be running 6S voltage, so what you have to decide is the capacity you need and the $$$ you want to pay. I would recommend no less than 45C/5000 mAh cells; either one pack for each motor, or to double run time hook two up to each motor in parallel, not series. You get what you pay for in batteries, the more you spend the fewer problems you will have. You don't need high-end packs for performance, but for reliability. Cheap packs don't last as long and you may have a cell go bad in a pack.
    You can run both controllers from your receiver by plugging them into the two throttle ports, or by using a common Y harness.
    • novice
      • Mar 2013
      • 9
      thanks fluid , what would the voltage be on the battery 7.4 , 11.1 or 22.2 per battery
      • BHChieftain
        Fast Electric Addict
        • 1964
        I swear by Hyperion lipos. Expensive, but I have over 20 packs, a bunch are 3 years old, and I have never had a problem with any of them.
        I've had very good experience with www.rcdude.com as a vendor for those.
        Chief
        • novice
          • Mar 2013
          • 9
          ok thanks for all the help i have decided to order
          2 x G3 EX 5000 MAH 3S 11.1V 45C/90C LIPOLY PACK
          this should be sufficient power and long run times
          • Make-a-Wake
            FE Rules!
            • 5554
            Went straight to the high quality stuff!! Good call
            • Rumdog
              • 6453
              You're gonna want 4 of those . Also, the kv rating on those motors is rather low for a twin 6s cat.
              • Make-a-Wake
                FE Rules!
                • 5554
                The rpms will be in the 28k range, not shabby, he can possibly use some 6 series Octuras with some diameter to get some speed...................
                • BHChieftain
                  • 1964
                  Should not skimp on doctors, lawyers, accountants, tires, .... and lipos....
                  They are an investment, but over the life of the packs I think they work out just as inexpensive as multiple cheap packs.
                  Plus, even used they sell real fast if you need to change your config.
                  Chief
