Can I use 4S Lipo in my Futaba transmitter?
  • JCAustralia
    • Jul 2008
    • 304
    Hi guys
    I recently modded my GT3B transmitter for 3S lipo power instead of the 6 AA batteries it normally takes. The difference is a huge improvement
    I also have a FM Futaba transmitter that I would like to convert to Lipo. The transmitter used 8 AA batteries.
    Can I use a 4S lipo battery without frying anything? Or should I use a a 3S lipo instead?
    If I use a 3S lipo I am concern that the voltage might be too low and if 4S too high
    Thanks a lot
    JC
  • HydroMike
    • Oct 2011
    • 334
    My guess would be too much power for it. But I did see some where someone made a volt regulater
    • TheShaughnessy
      • 1431
      8x1.5 = 12. 3s lipo, fully charged is 12.6v. Strange though my gt3b used 8 AA battering before I converted to lipo
      • NativePaul
        Greased Weasel
        • 2761
        I use 3s in my Futaba 6EX and it is great, the voltage is a little higher throughout the discharge, Saughnessy mentioned the fully charged voltage, but the nominal voltage is also higher 8x1.2v=10v, 3s LiPo 3x3.7v=11.1v, and empty, 8x1v=8v 3s LiPo 3x3v=9V, the only downside is that once the low battery alarm goes off you need to charge up within 10mins or wreck your battery, whereas with NiCd/NiMh you probably have half an hour.
        • HTVboats
          • Jun 2011
          • 803
          I have switched my Futaba and Flysky's to 3S lipos and not looking back. You do have to be careful not to leave your TX on as once you bury a lipo it's not comming back. If that becomes a problem then on to 3S Life's.
          Mic Halbrehder
          IMPBA 8656
          NAMBA 1414
