Batteries are getting hot and puffing
    • 9488
    Originally posted by mtbenjamin77
    get some sky lipo 30c from hobbypartz about $40.00. I've been running my SV27 on 5s2p with the aqua 60amp esc. I run it down till it cuts off almost everytime. I'm putting 2800mah back in a 2650 mah pack. And still no puffing and they balance just fine. the best part of it is if i do ruin them they're only $40 not $100+.
    I'm betting those packs are actually 3300's not the advertised 2650mah
    • mtbenjamin77
      • 761
      I use two of these and they're only $30.00
        • 9488
        http://www.hobbypartz.com/77p-sl2650-5s1p-30c-5555.html
        If I didn't have so many packs right now, I would try some of those out..
        thanks for posting..
        • ethomp
          • May 2012
          • 8
          Just got back from another run with a pair of zippy soft packs 5000mah 45c 2s, move the strut down 1 1/8 in from 3/4 in. and man was she flying. Set my timer at 3.5 min for a total run of 4 min. and the batteries showed 3.70v each and took 2211mah to re charge them, so I think 4 min. is going to be the max time for this set up.
            • 9488
            Glad to hear you got a good run!
            Where is the bottom of your strut to the bottom of the sponsons?
            Thanks
            • 785boats
              Wet Track Racing
              • Nov 2008
              • 3169
              You do have a couple of other options.
              A lipo Shield is set at 3.2V cut off & that usually leaves some capacity in the pack at cut out. You would have to do some testing. But it would be cheaper than new packs & you could use your good race packs.
              http://www.offshoreelectrics.com/pro...hld-32&cat=136
              Or Replace the ESC with one that has programable cutouts that can be set to 3.2 or 3.4V You would only need a $50.00 Turnigy 120A for that set up.
              • ethomp
                • May 2012
                • 8
                Not sure how to get that mesurement I took it from bottom of hull to bottom of the strut where the prop shaft goes through. I ended up moving the strut back up 1/8 in. might be alittle slower but I seem to have more control in the turns. THIS THING IS TO FAST FOR OUR LITTLE POND!!! Need to find bigger waters.
                • Stinger9D9
                  • Jun 2007
                  • 355
                  #23
                  It's also worth mentioning that the 40x57 prop is not stock on the UL-1. It's actually a pretty agressive upgrade that pushes things that much harder. You may want to try a 40x52/3. The lower pitch will slow things down a bit and lower the current draw.
                  I've been messing around with mine on that prop (and I have a pretty good "internal timer" that reminds me when it's time to bring her in), and everything stays nice and cool.
                  FWIW, I've never ran a set of batteries down to the stutter bump on an AQ ESC. I always suspected they go way too low for my comfort level.
                  • Make-a-Wake
                    FE Rules!
                    • 5557
                    #24
                    Something doesnt add up here.....................you took them down to 3.7v per cell and they only took 2200mah.........????......less than half of the capacity.........???....either you had a typo or the charger quit way before they were done or they are not 5000's. My 5000's take 5000 or better when at 3.7 resting voltage.
                    • ethomp
                      • May 2012
                      • 8
                      #25
                      Yes your right, that 3.7v reading was taken from another pack just forgot to go back and change my typo. I've been testing a brass 40-52 and it runs real good on that prop I just lose top end speed but after 4 min everything comes off nice and cool. I also ran a brass L40-57 and I think its out of balance because the back end starts to wag like a dogs tail. The best prop so far have been the stock plastic ones [sv27] I though I read somewhere that they were a 40-57? I need more batteries, these 4 min runs suck!!
                      • Make-a-Wake
                        FE Rules!
                        • 5557
                        #26
                        Try an x442.............a 2 blade will rev our better.
                        • ethomp
                          • May 2012
                          • 8
                          #27
                          I'll try that, thanks
