Diesel Battery Testing:
  • RandyatBBY
    • Sep 2007
    • 3915
    #76
    You did not put the run time on all the packs it is necessary to understand temptitures of the packs. The longer you run and the more amp draw compared to the discharge C rating the hotter the pack will get. A good pack will discharge close to it max C discharge rating and not get over 130F over the full discharge leaving 30% when done discharging.
    I did like that you type in the results. I could not see all the graphs (on my lap top) even after I clicked on them. On my desk top with a bigger screen it was fine.
    Randy
    BBY Racing
    • RandyatBBY
      • Sep 2007
      • 3915
      #77
      Now that the packs are broke in I would like to see some bigger discharges, more in the 85% amp discharge.
      Randy
      BBY Racing
      • Paul Susbauer
        • 18
        #78
        Hi Randy,
        Diesel sent me an email a while back saying he was taking a little bit of a break from boats for a little bit.
        In my laboratory testing, you are correct, 130F is a good cutoff. The best cells I see never reach that temp until the very end of the pack, even when pushing them. I actually see hotter running temps at middle range Amp loads. Basically high enough amps to heat up the pack, but low enough that they'll have a long run. At the high current levels, the pack doesn't have time to heat up...
        I've also found that some packs will give better performance the harder you push them.
        Example. I've tested some say 30C packs at XYZ current, and then test a 60C pack at the same current. Putting their voltage under load side by side, they look about the same. Push that 60C pack harder, and it seems that it'll have the same voltage. If anything, I'll get at least a better discharge profile.
        On the soldering to the tabs... you need a special solder to correctly solder to the tabs. Your run of the mill hardware store solder isn't up to the task.
        --Paul Susbauer
        Venom Group International
        • Diesel6401
          Memento Vivere
          • 4203
          #79
          Back from the dead (so to speak)....
          Since my small break (not by choice, medical issues) I have been using the Venom packs in my Blitz with no issues, we know that the amp draw is a lot lower, but the migration on the bullet connections into the hard case has stopped. It does worry me though that it will continue if used in setups pulling 60+ amps. I am not sure if the bullets pressed in the case are 3.5mm or 4mm, and they are just not going to handle the amp draw without heating up to bad. They are without a doubt one of the biggest weak points of these packs.
          The Motley Crew is a lot different now. New setup is a Swordfish 200 with a Leopard 4068 2350kv and a modified x447/3 that is now 42mm in diameter and detongued. I ran 3 different packs (no data logging), the 2s 6000mah nano-techs keep tripping the low voltage cutoff throughout the run they did not handle the amp draw well at all. The repair job I did though is holding up. The Turnigy packs are just so hit or miss. Also I recently read that someone received some Turnigy (non nano-tech) packs and the output wires where switched... Just terrible QC. With the same setup listed above I then ran 4s2p with some Turnigy 4s 3600mah packs and the performance was just fine which was to be expected with a 2p setup. I then ran the Gens Ace packs in 4s1p and no issues with tripping the lvc. Needless to say I was amazed. I didn't run the Venom Packs due to the migration issue.
          I wonder if there is anyway that I can open that hardcase and solder on a larger bullet connector onto the pack or even bypass that completly and just hardwire directly to the cells to eliminate extra resistance...
          - Diesel's Youtube
          - Diesel's Fleet
          • Diesel6401
            Memento Vivere
            • 4203
            #80
            Did find this post this morning: http://www.rcgroups.com/forums/showt...7#post20861114
            - Diesel's Youtube
            - Diesel's Fleet
            • Drax21
              • Jul 2011
              • 1021
              #81
              I believe Venom nearly lost all of their business on Lipos a few years ago as their packs were under performing and sometimes failing all together. They are now using a different mix in the Lipos and they say that they can contend with the best. They seem way overpriced but I have not retried any
              Diesel, In order of 1st 2nd or 3rd where would you put the Venom packs?
              Everything that has a beginning, has an End
              • Diesel6401
                Memento Vivere
                • 4203
                #82
                Originally posted by Drax21
                Venom nearly lost all of their business on Lipos a few years ago as their packs were under performing and sometimes failing all together. They are now using a different mix in the Lipos and they say that they can contend with the best. They seem way overpriced!
                Number 1: Gens Ace packs
                So far without a doubt the Gens Ace packs are the best. I have tried them in sereral different setups and they performed without a issue everytime. I was impressed with how they handled the new Motley Crew setup especially sense the Nano-Tech which are a higher mah (5300mah vs 6000mah) with the "same C" rating. I suspect (just my thoughts) the Gens Ace C rating is more accurate then the Turnigy packs.
                I use Gens Ace and Sky Lipo batteries in my planes as well and also have Turnigy packs. When I swapped from my Turnigy packs to a Gens Ace packs (same with the Sky lipo) I swear the plane was a whole different plane. The performance was increase was amazing, even my rc buddy who has been involved with all the battery information asked "what the hell did you do to thing" I said switched to Gens Ace his response was "damn it's a whole different plane". Now that's just a story no data noted or gathered, but the difference is very VERY noticable. In planes the instant "punch" is very noticable.
                Tied for second: Turnigy and Turnigy Nano-Techs
                I was disappointed in the fact the Nano-Techs struggled and the Gens Ace packs shinned. The Nanos are suppose to be HK "higher end" line so to speak and I have read constant issues about them failing and having problems then my issue with the bad solder joint came about so QC is still the issue for them. My old orginal Turnigy 2s 5000mah 40c packs are still running awesome though. In terms of price and performace they rock as well!
                Third Venom Packs:
                To be honest I expected more for the price, the bullets pressed into the hardcase ( done in other brands also) is a downfall on these packs in the boating world. I'm still putting cycles on them in my land vehicles then I would like to try again in boats, but I need to do something about the bullets pressed into case. They simply aren't going to handle the loads us boaters put on them. I'll be on "house arrest" for a few weeks starting on Wednesday (back surgery), in that time I would like to come up with some solution on replacing those connectors then I can push them a little bit harder.
                Lot's all be honest the first thing we change on any rtr boat out of the factory is the deans connections and the small bullets on the motor/esc combo (especially on the PB motor/esc's they are 3.5mm and I think AQ uses maybe 4mm). The 3.5mm are only good for around 35 amps or so (i think) and the 4mm maybe 70amps max. So the pressed in connectors either 3.5mm or 4mm are being pushed to there full limits on a stock rtr boat. We all know that we don't stay stock very long in sport boating. Props get swapped larger esc's put in ect ect... All my motor/esc connections are 5.5mm on spec motor/esc's and 6mm, 6.5mm and 8mm on other motor/esc combo's that I have so there is in issue with the small connections. Until that gets fixed, using them in any of my boats is just pushing things to max and knocking on the possibility of a failure.They are hardpacks better served for cars and such, be we all know that are used in boating as well.
                - Diesel's Youtube
                - Diesel's Fleet
                • Diesel6401
                  Memento Vivere
                  • 4203
                  #83
                  I do wish (and Paul I am sorry for this) I was able to gather more information over the last year for your guys, but needless to say "life is always changing". I love my rc time, but that time (and extra money) has shrunk quit a bit last few months. A newborn will tend to do that...
                  - Diesel's Youtube
                  - Diesel's Fleet
                    • 7651
                    #84
                    Well maybe those that are interested can keep an eye on our packs and post on our observations here.I have a set of high dollar Thunder Power packs and some Sky's that I am paying attention to.Trying to keep the same cycles and same boat runs.So far the TP's sure hold a balance better.
                    I think a thread like this is important for those contemplating spending $170 on a single 4s pack compared to $40.
                    Hope everything is going better for you Deisel on your home front.
                    • Boaterguy
                      • 1760
                      #85
                      I'll keep an eye on my haiyin packs. I don't have data logging but I have a haiyin 4S 5000mah 40C and a zippy 4S2P 5300mah 45C, i'll compare them.
                      • Diesel6401
                        Memento Vivere
                        • 4203
                        #86
                        That sounds like a good idea to post your logging here. Data is always good as well. Things are getting a lot better on my end. My son (now 6 months old) had open heart surgery back in November and is doing AMAZING! I myself am actually having back surgery this wed the 29th so all in all things will be getting back to "normal".
                        O I am very interested in how those will do. Been looking at those packs.
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • Boaterguy
                          • 1760
                          #87
                          the only way to get them here was to take ups or to fork over 75$ in shipping. it ended up costing me 50$ to get my 60$ pack here, but that's ups, not haiyin so I can't blame them.
                          it looks really nice though.
                          • Diesel6401
                            Memento Vivere
                            • 4203
                            #88
                            Where are they located at? Shipping my not be as much to the states...
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • Diesel6401
                              Memento Vivere
                              • 4203
                              #89
                              Thread I started on the Haiyin Batts http://forums.offshoreelectrics.com/...iyin-Batteries
                              - Diesel's Youtube
                              - Diesel's Fleet
                              • Boaterguy
                                • 1760
                                #90
                                Vegas I think.
                                I will contribute to that thread with my findings.
