Diesel Battery Testing:
  • Diesel6401
    Memento Vivere
    • 4204
    #91
    Originally posted by Boaterguy
    Vegas I think.
    I will contribute to that thread with my findings.
    O sweet, shipping shouldn't be any issue in the States then.
    Sent from my T-Mobile G2 using Tapatalk
    - Diesel's Youtube
    - Diesel's Fleet
    • Boaterguy
      • 1760
      #92
      yeah, although going to windsor, back to illinois, going to three post offices in illinois, going to windsor, then coburg, then arriving is an issue with shipping for me.
      I'm gonna stick with gen's ace from now on, they seem to be the best.
      • Paul Susbauer
        • 18
        #93
        Hey all,
        To note, as an update from Diesel's initial posting and when I sent him samples, the exact case style that he has is no longer in use. We are taking a good hard look at all of our batteries and looking at what we can do to improve their construction for boat use. One thing I would avoid, no matter what brand you buy is the bullet with plug in leads and would go only with the hard wired packs. You're eliminating one set of plugs to go bad or raise resistance.
        About the hard wired packs, we have three different hard wired, High C rate packs. The top of the line currently is the 50C 5000mah, p/n 15058.
        To Diesel also, no worries about the time or info, take care of yourself before your hobby's. :D
        --Paul Susbauer
        Venom Group International
        • Drax21
          • Jul 2011
          • 1021
          #94
          So according to the fact that Diesel had the plug in packs with extra resistance, another test with hard wired packs could be more thorough as to compare performance. The support for Venom batteries has risen rather rapidly in the UK since the new lines came out. Mostly in the car racing field.
          Venom 50c 5000mah - $149.99 Hyperion 45c 5000mah- $148.95 ----Here would be a good test in a boat.....
          I'm currently have Hyperion 4s 4200mah 45-90c which I will be testing against cheaper batteries Winmax 4s 4200mah 50-100c. Will start a review within a month.
          Everything that has a beginning, has an End
          • Drax21
            • Jul 2011
            • 1021
            #95
            How is the pack constructed inside the hard case?
            I would think about opening that case and a little re-wiring and wrapping job if they would be no use to you otherwise. (this would void the warranty if purchased)
            I would still expect wires coming out of the pack inside the case into the 4mm.
            Wrapping or shrink wrapping the whole battery and then sticking the label that was originally on the hard case would make it look fine.
            The wires inside would be pretty short but should be easy enough to lengthen. Twisting wires together and soldering through adds little to no resistance if done correctly.
            The 4mm connectors obviously to be replaced by 5.5mm
            I have seen a few of your battery repair jobs before diesel, I'm sure you would be up to the task
            • Diesel6401
              Memento Vivere
              • 4204
              #96
              Already did it lol. Here's what I came up with. The 4mm bullets by far the week point. Inside short 12g wire attached the cells to the 4mm bullets, so you end up with wires to bullets then more wires attaching to the bullets. Lot's of resistance. Other companies do this as well, I'm not a fan though. So I thought of reusing the hardcase for use in land rc's and removing the cells from the case for boating. I modded the shell, and hardwired 12g to the cells, I will be replacing that 12g with 8g though I just need to order some red 8g to make it right. I also thought of dumping the reusable shell idea and just wrapping the cells as they are and making them soft packs. Not sure what I wanna do. I saved weight though.
              First pic is cells outside of hardcase shell
              Second pic slide into the reusable shell
              Third pic the top is mine modded the lower is the stock from venom
              Fouth is weight of just cells (9.2oz)
              Fifth is stock with wires (11.2oz)
              * my scale is not calibrated so maybe a few oz off.
              - Diesel's Youtube
              - Diesel's Fleet
              • Diesel6401
                Memento Vivere
                • 4204
                #97
                1st: pack opened
                2nd: you can see how much extra space is used/needed for the wiring/connection setup
                3rd: 12g to the 4mm post
                4th: 12g hardwired
                5th: balance plug (i use extensions from HK, 10 for like $2 and I make my own balance plug any length i want)
                - Diesel's Youtube
                - Diesel's Fleet
                • Skater
                  • Feb 2012
                  • 9
                  #98
                  Fifth is stock with wires (1lb 1.2oz)
                  I think you mean #4 is 9.2 0z
                  #5 is 11.2 oz
                  that would be 2 oz for the case & extra wires
                  Dirk
                  • Drax21
                    • Jul 2011
                    • 1021
                    #99
                    Good job Diesel. Good idea with a re-usable hard case!
                    • Diesel6401
                      Memento Vivere
                      • 4204
                      #100
                      #5 is 11.2 oz
                      Dirk
                      Yes sorry
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • lenny
                        • Sep 2010
                        • 4293
                        #101
                        Hi Dale,
                        Thanks for all the info.
                        Where did you buy your little black cell tester and is it good for all packs ?http://forums.offshoreelectrics.com/...7&d=1318229995
                        ? ONLY IF THEY WORK
                        • Drax21
                          • Jul 2011
                          • 1021
                          #102
                          I also would be interested in that mini cell voltage meter
                          • Diesel6401
                            Memento Vivere
                            • 4204
                            #103
                            This is the little cell tester I have http://www.hobbyking.com/hobbyking/s...8S%5FLipo.html
                            Steve here at ose and Jan at kintec sale some similar products. There is a futaba unit I'm eyeing up http://kintecracing.com/Electrical.html
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • Steven Vaccaro
                              • 8720
                              #104
                              This one is the best I've used
                              http://www.offshoreelectrics.com/pro...rod=emp-Sentry
                              The mini black one is cheap and I do use it as a backup, but the Hyperion is much faster to powerup and give a reading.
                              • lenny
                                • Sep 2010
                                • 4293
                                #105
                                How will does the one from hk work for you ?
                                ? ONLY IF THEY WORK
