I purchased two kits from Blazermarine.com. A whiplash sport 20 and a whiplash sport 40. This thread will cover the sport 20 build for FE. I will be installing a nitro motor mount though in the event I decide to convert back and forth between FE and nitro.
A few comments about the kit:
Considering that this is my first boat build EVER some of my comments may seem a bit novice in nature. So please forgive any inaccurate terminology.
The frames, formers, and decking are cut from aircraft grade plywood using a CNC laser machine. I didn't realize why that was important until I started to dry fit everything. The framing went together in about 5 minutes and everything was snug and flush. This was a pleasant surprise!
The instructions are a bit lacking for a novice builder however. I had to read it several times in addition test fitting the different pieces before I tack glued anything in place. Hopefully my pics and commentary will help others. The manual was not included in the box, but can be downloaded from here. LINK
The only "jig" that is required for the build is a flat surface.
Pics to following in the next post.
