Here's finishing instructions that may be helpful. I copied and pasted from Zippkits FE rigger plans.
Sand the tub and sponsons, but be sure
to leave the overhangs.
Fill any holes or imperfections with wood
filler.
Sand everything with 150. Seal the tub and sponsons with epoxy
finishing resin or West Systems epoxy.
Be sure that all wood is sealed.
Scrape off as much epoxy as you can. It
will make sanding easier.
When cured, sand with 150 and recoat
with epoxy.
This coat will use far less
resin than the first.
When this cures, wet sand the bottom of
everything with 220.
If you are painting, sand the entire boat
with 220. Now is the time for primer. Wet
sand the primer with 400, and use spot
putty to fill any imperfections. Wet sand
with 400 and lay on a heavy coat of
primer. Wet sand with 600-800 and
paint.
filler.
with epoxy.
paint.
