Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 Carbon Fiber - Offshore Electrics Forums
Carbon Fiber
  • sailr
    • Nov 2007
    • 6927
    Looking for cloth, not sheets.
    McMaster-Carr. Reasonable prices, beautiful glossy sheets, fast shipping.
    Mini Cat Racing USA
    www.minicatracingusa.com
    • sailr
      • Nov 2007
      • 6927
      That is a good deal. Just bought 2 pcs. Thanks!
      Originally posted by line6
      http://cgi.ebay.com/3K-PAN-Carbon-Fi...QQcmdZViewItem
      This is the stuff i have used, its not much fabric but if you just want to try it out for yourself this is more than enough. I am no pro at this but i'm happy with my results
      Mini Cat Racing USA
      • properchopper
        • 6968
        They also have, alphabetically : bars, cloth,fabric, hollow rods, laminate,rods, sheets and tubes. You're right, the ebay deal looks good BTW.
        • jcald2000
          • May 2008
          • 774
          This is who I use for cloth.
          • Ken Haines
            Racer
            • Jul 2007
            • 647
            Carbon Fiber
            Try
            US Composites
            561-588-1001
            West Palm Beach, Florida
            America's leading distributor of composite materials. We combine superior products and the industries' lowest prices with fast and accurate service.
            They have a large variety of carbon fiber rolls & tape.
            We also use their expanding foam and epoxies.
            Paul Pachmeyer put me on to them, from my experience
            they have good stuff and excellent customer service.
            The carbon fiber is not that expensive either.
            Ken
            TenShock Brushless / Pro Marine
            INSANE Boats / Rico Racing/ Castle Creations
            2023, 2024 NAMBA & 2018 IMPBA FE High Points "National Champion"
            • FastVee
              • Aug 2008
              • 649
              Is 193 g/m² carbon fibre too thick/heavy? -it is the only thing I could find locally .
              It is 59€/1 square meter thought! (ose has none in stock) ,but that should last for few boats.
              www.youtube.com/rangerpate
              • ghostofpf1
                • Jun 2008
                • 392
                I have used 5.7oz per sq yd cloth with good results so your cloth should be just about right
                Steve
                • sailr
                  • Nov 2007
                  • 6927
                  That is 6.8 oz per square yard. a square meter is 1.19599 square yards. So it is 5.68 oz per square yard. Perfect!
                  Mini Cat Racing USA
                  • FastVee
                    • Aug 2008
                    • 649
                    Yeyyy! Thanks guys!
                    I just talked to a friend, and he wants half of it, so the price is not that bad anymore.
                    50x100cm to both of us should last a while! -you only use one or two layers when strengthening hulls ,right?
                    And do you think it is best to use reguar epoxy or laminating epoxy? The same shop that carries that cloth has laminating epoxy that suites fiberglass,carbon fiber and kevlar.
                    That is cheaper then reg.epoxy so idk about the strenght.
                    • ozzie-crawl
                      • Sep 2008
                      • 2865
                      just use one layer its a lot stronger than fibre glass you will notice how much stiffer the hull is once done
                      • ozzie-crawl
                        • Sep 2008
                        • 2865
                        one word of warning once you start using c/f you get addicted
                        • sailr
                          • Nov 2007
                          • 6927
                          #27
                          The laminating resin is what you want. The strength comes from the cloth, not the resin (epoxy).
                          Yeyyy! Thanks guys!
                          Mini Cat Racing USA
                          • FastVee
                            • Aug 2008
                            • 649
                            #28
                            Looks great Ozzie!
                            Sailr, thanks for that info!
                            Just got that cloth, it looks so cool, can“t wait much longer for that cat to arrive so I can start...-it takes 1-2days right from hotr
                            I also took that laminating epoxy with me.
                            Pate
                            • ozzie-crawl
                              • Sep 2008
                              • 2865
                              #29
                              iam no expert with glassing and carbon fibre but i will tell you a few things i have found that may help. i brush on a layer of resin first then lay the cloth on top then brush resin over the top,well not so much brush but push the resin in to the cloth, on flat areas a small foam roller works very well, i usally put resin in the middle and work my way to the edges that way you dont end up with excess resin as you dont need to flood it, use thin disposable rubber gloves, these are really good when doing cats as you can use your fingers to help mold the cloth over the ridges etc, when i work out what size piece of cloth i need (usally a paper or cloth template) i spray a thin line were iam going to cut with hair spray to stop the edges fraying,this helps a reall lot just dont use to much other wise it becomes to stiff
                              hope this helps
                              • sailr
                                • Nov 2007
                                • 6927
                                #30
                                Great tip about the hair spray!! Thanks!
                                Mini Cat Racing USA
