Mean Machine Catamaran (Sport)
  • Chilli
    • Jan 2008
    • 3070
    #61
    Guys, What rudder offset are you running with the speedmaster hardware???
    Thanks!
    Mike Chirillo
    www.capitolrcmodelboats.com
    • lomdel
      • Nov 2008
      • 708
      #62
      Any more exciting MM set-ups? I am on the verge of ordering one, selling all my 3S packs and using my 11XL on 5S2P in this hull. Would start with the X442 prop, or not?
      Then I will de-convert my TC31 back to nitro...
      • ReddyWatts
        • 1711
        #63
        X442 sounds like a good place to start with your setup. I like the 6s 11, 12 and 13XL setups in the MM.
        ReddyWatts fleet photo
        • bustitup
          • Aug 2008
          • 3071
          #64
          I confirm thread should b sticky
          Mr watts .....your thoughts on my setup
          1515/2,5d. 1650kv
          Hi model 200amp
          6s or 5s 5000mah 25c/50c
          Should I use a thrust bearing?
          Prop suggestion for 40 50 60 mph?
          I will have fan and water cooling like you
          • lomdel
            • Nov 2008
            • 708
            #65
            11XL and even 12XL on 6S amounts to too many watts, not so Reddy? Thats why I used 13XL on my 6S set-up in a 31" cat. Would the 11XL on 6S in a MM hull be that much different?
            • ReddyWatts
              • 1711
              #66
              I would run them with the Y537/3 prop. Not to many watts. It works well on the MM hull. I have a new prop that would be like a Y538/4 that I am going to try on the MM.
              Bustitup
              Cant help with this setup. Maybe someone will chime in from their experience?
              1515/2,5d. 1650kv
              Hi model 200amp
              • DISAR
                • Aug 2007
                • 1072
                #67
                I will propose something according to some calculations which I do for my motors (recently run the 1512/2D in the MM with good results). First of all it is better to run 6s and the below info is for 6s1p and the speeds are approximate
                M or X 440, 70 amps, 40mph+
                642 or x445, 105 amps, 50mph
                645, 135 amps, 60mph
                646, 145 amps, 60mph+
                http://www.rcfastboats.com/
                • bustitup
                  • Aug 2008
                  • 3071
                  #68
                  whats the difference a m or x prop.....is this info all on the 1512 motor?
                    #69
                    You will blow your ESC if you try to run 6S on a 1512/2D with an m645. Those props and speed suggestions cannot be for anything but a calculator.
                    Your 1515/2.5D motor is really too much for 6S except for racing. It would work fine on 4S but 60 mph is out of the question. Run an x445 for sport and an m545 or m645 for speeds in the 45-50 mph range on 4S. If you want more speed you'll have to get a different motor for either 4S or 6S, unless you enjoy buying ESCs regularly.
                    The 'M' series props are just like the 'X' series with the same number, except they have some blade area removed from the leading edge (tongue).
                    • bustitup
                      • Aug 2008
                      • 3071
                      #70
                      Fluid I was hoping you would chime in....I thought I was going to have to pm you
                      first of all I found it hard to believe he was running 6s on a 2500kv motor and living through it without causing a melt down
                      My actual first choice for the motor going in my MM is my 1515/2.5d 1650 kv
                      I heard good things about the Hi model 200 esc and ordered one two days ago I will modify it with Steve's cooling plates and then water proof it
                      My plan was pairs of 3s lipo's or one single 5s.....please give me your choices for props to go 40 50 60+ mph
                      thanks in advance
                      nick
                      • Mel279
                        • Dec 2008
                        • 857
                        #71
                        Mr Jay, what motor should I use if I want to go for 6s?I've got feigao 12xl, is this ok?are there any device which could protect esc from blown or fried?
                        • calcagno45
                          • Mar 2008
                          • 1006
                          #72
                          12xl should be great on 6s!
                          • Mel279
                            • Dec 2008
                            • 857
                            #73
                            Hey thanks, what cutoff voltage should I set on hydra 240 if Im using 6s?with 12xl motor, can I reach 60mph on that?
                            • Mel279
                              • Dec 2008
                              • 857
                              #74
                              3657/4 is 36mm in diameter, 57mm pitch.
                              3857/4 is 38mm in diameter, 57mm pitch.
                              3861/4 is 38mm in diameter, 61mm pitch.
                              I got the info from OSE store
                              Is this prop suitable for mean machine with 6s setup?
                              • DISAR
                                • Aug 2007
                                • 1072
                                #75
                                The info I gave you is based on your motor and not mine.
