Miss elam
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7119
    I managed to get it w/in 1.2" behind the sponson's ride pad. This is a better reference point. I had to add two 3oz ballast strips to the nose - poked way up in the sponsons. Then I have the motor up in the cockpit with the batts as far forward in the tunnel. I may be adding more ballast if need be. I had a dead nicad pack in each sponson and it rode real nice, then I dunked it and decided to remove the batts before they rotted or leaked.
    I put one of those bearingized struts on there and am reeeeeally happy with it. Looks good, man I love this boat - its my wife's favorite of the fleet!
    "Look good doin' it"
    See the fleet
    • wolf IV
      • May 2008
      • 961
      QUOTE=Jesse J;104481]I managed to get it w/in 1.2" behind the sponson's ride pad. This is a better reference point. I had to add two 3oz ballast strips to the nose - poked way up in the sponsons. Then I have the motor up in the cockpit with the batts as far forward in the tunnel. I may be adding more ballast if need be. I had a dead nicad pack in each sponson and it rode real nice, then I dunked it and decided to remove the batts before they rotted or leaked.
      I put one of those bearingized struts on there and am reeeeeally happy with it. Looks good, man I love this boat - its my wife's favorite of the fleet![/QUOTE]
      OK. I CAN STICK THE ENTIRE BATTERY (4S1P ) IN THE NOSE, SO IM HOPING THIS WILL DO IT? ILL CHECK IT OUT TONIGHT, IVE GOT TO GO DO A SIDE JOB FOR SOME EXTRA CASH RIGHT NOW..
      http://www.youtube.com/watch?v=e-npTLBHefY
        • 9488
        Cannot wait to see the vid on this when running!
        • Jesse J
          scale FE racer
          • Aug 2008
          • 7119
          What motor/esc you gonna use? Still have a BJ motor? I have tried both and it runs great, but my UL1 setup makes if FLY!!!! Just made a couple laps in the community pond and dodged the fountain and hopefully the monster gold fishies that cruze round in there. I'll try to talk my wife into filming later.
          See the fleet
          • wolf IV
            • May 2008
            • 961
            PLEASE DO IT , DO IT, DO IT.....ID LOVE TO SEE A VIDEO!!!! IM GONNA USE A turnigy 36-50-2300 KV same specs as ammo ... WITH A FAN COOLED HI MODEL 200 AMP ON 4S1P 5100 MAH .. WHAT DO YOU THINK?
            • Jesse J
              scale FE racer
              • Aug 2008
              • 7119
              great motor, I think the ESC will be overkill, but better than smokey joe! batt sounds good, have you located your COG? I will try this evening or early before they turn on the blasted fountain.
              How did your side job go? did you get away with it?
              See the fleet
              • wolf IV
                • May 2008
                • 961
                dude side job was great but lost all the money going to the E.R due to seveer flash burn to my eyes from tigging for 7 hrs!!!! CRAZY PAIN!!!I WAS LITTERALLY BLIND FOR 3 HRS...and ive had my spleen out, 2 bad moto crashes requiring surgery, and almost lost 3 fingers and this was up there in pain!!!!! it felt like i woke up out of my sleep with glass packed in my upper eye lids.............. have not locted cg, will do right now!over kill is my name!!!!what do you think about this combo? is it fast??? you know, how ( I ) like it??? or do i need more power, rpm's???
                • wolf IV
                  • May 2008
                  • 961
                  well mines at 3.2"right now, but i can move my esc up to yhre front and itll be 2.2".... i dont understand why the cg has to be so far up from stock set up??? stock cg is prop. around 4-5'' .....
                  • wolf IV
                    • May 2008
                    • 961
                    Fabbed up the harware.. And intalled. Im happy with it. My cg is still 2.2'' back though? i think ill run it and see? THE ORIG. STUFF TUBE SITS PRETTY LOW , SO THE BUTT WILL COME OT OF THE WATER PRETTY HIGH.. SO ILL WAIT AND SEE, I HAVE A HUGE FEELING ITS GONNA BE WAY TOO LOOSE! ILL PROB. HAVE TO PULL OUT THE STOCK TUBE.. ILL DO A WET TEST FIRST..
                    • Jesse J
                      scale FE racer
                      • Aug 2008
                      • 7119
                      I know you want to get her wet, but I think you might want to reset your stuffing tube. Check my postings on how I did that, it will give you lots more adjustability both up/down but also angle (which controls the bow). While you are removing stuffing tube, you could go to .078 wire drive, actually no I want to keep my advantage.
                      COG needs to be up there if you want her to stay on the water, especially at your desired speeds. Recall Darins thread where he keeps adding lead to the bow - the stockies didn't worry too much about getting this right it appears. Also you added a bunch of CF, as did I and that is all BEHIND the COG. Do us both a favor and keep working on it until it is w/in 1.5". Get yourself 4 strips of the 3oz lead ballast with adhesive they sell the airplane boys and stuff it into some pipe insulation/pool noodle then jam that up into the sponsons as far forward as possible.
                      Good luck and what is tigging? you sound like you treat your body like you do your boats???
                      See the fleet
                      • Darin Jordan
                        • 8335
                        If you look through my Elam Race Prep thread, you'll see the mods I did to my stuffing tube... Might help some.
                        I ended up adding over 6oz of lead to the nose of the hull to get the CG "right". I'll have to measure it to give you the exact distance at this point, but I think you'll find it necessary to add the weight to get it right. Anything less and the boat gets really squirely once you exceed 40mph...
                        I initially started out with the lead taped underneath the front cannard wing, until I figured out the right amount. Then I did some fancy drilling and installed tube-lead (1/4" OD fishing weight lead) into the front of the boat through the side of the sponson and through the front cannard-wing. Works pretty well now.
                        Darin E. Jordan - Renton, WA
                        • wolf IV
                          • May 2008
                          • 961
                          #27
                          Not what i wanted to hear, thanks guys..TIGGING IS SHORT FOR TIG WELDING.
                          • Jesse J
                            scale FE racer
                            • Aug 2008
                            • 7119
                            #28
                            You evidently don't know what RTR stands for...
                            Ready To go work on it in the shop for a week or so and then do the first test Run
                            I guess they should call it RTGWOIITSFAWOSATDTFTR...... But I guess RTR is easier to remember.
                            See the fleet
                            • wolf IV
                              • May 2008
                              • 961
                              #29
                              Originally posted by jesse j
                              you evidently don't know what rtr stands for...
                              ready to go work on it in the shop for a week or so and then do the first test run
                              i guess they should call it rtgwoiitsfawosatdtftr...... But i guess rtr is easier to remember.
                              hahahaha, lol!!!!! This is only my second "rtr" as the super v was my first boat ever... I reserched and waited for the sv27 to come out,.. Loved it!!im kinda unmotivated now, but will finish it next week !!!
                              • avery
                                • May 2009
                                • 92
                                #30
                                flash burn
                                hey have a quick fix for flash burn use vicks salve just as you lye down close eyes and put on like fotball player do black under eye trick is don open eyes after you put salve and in seconds the pain goes away and warm feeling trust me i know ive been tig welding for 20 plus years it works i keep vicks by bed lo
