Thanks HotH2O
Diegoboy's Stretch Renegade rigger
She is in need of a decision (paint scheme) She's easier to paint now than to tape her off later."A quick temper will make a fool of you soon enough."
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Bruce Lee. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Comment
AHHH. True. I bought mine pre-built. I got lucky and she was done right. It's not painted. I kinda like the wood look but, i'm already trying to figure a paint scheme out. Have you had any issue removing the self tapping screws and replacing them?Comment
1st round of paint... wish me luck.Attached Files"A quick temper will make a fool of you soon enough."
Are you gonna prime first, or no? Reason i ask is that I just sanded the heck out of mine to paint. Taped it up, primed a sponson, annnnnd the epoxy in a few spots started breaking up. Guess automotive primer wasn't a good choice on my part. Decided to sand off the prime. I think i'll stick with the wood look for now. Did you pick your motor for the stretch yet? If you go with a higher kv are you gonna go with a bigger esc or no? Good luck!!Comment
Ryan, try using spray Kilz first...then sand lightly and then use Krylon primer (2 coats...sanding in between coats) then Krylon spray paint. That combo works really well for me, and I have yet to see any peeling from hatch tape or anywhere else for that matter...
-KentComment
I found a can of krylon white primer in the garage. I peeled off all the tape and primered the hull. I can't post a pic because the wife is on the desktop. I will post it later.Last edited by Diegoboy; 07-22-2009, 10:34 AM."A quick temper will make a fool of you soon enough."
Primer photo as promised.Attached Files"A quick temper will make a fool of you soon enough."
FYI
Yellow krylon doesn't sit well when sprayed over with krylon "fusion" blue. I knew better, but Fusion was the only blue I had.
Gotta strip the blue and try again. I hope I don't have to strip the yellow too."A quick temper will make a fool of you soon enough."
Sorry to hear about that Danny...I've never used Krylon Fusion before...only Automotive Krylon sprayed over Automotive Krylon. Hmmm...it is made for plastics so it must have a different bonding agent that actually sets into the plastic, which the regular Krylon does not mate with very well.
Hopefully you can get it cleaned up ok, then try again with the regular Krylon...
-KentComment
