Intruder s
  • bigpapa
    • Apr 2009
    • 2330
    boat is wire drive, and if you look the rudder is on the right side, the servo is lined up straight with the rudder ......... see second picture
    • Gerwin Brommer
      • Dec 2008
      • 918
      Why not the steeringrod on the left arm of the rudder, and servo left from the center ?
      With a singledrive cat you want as much weight on the left side as possible ?
      • LuckyDuc
        Team Ducati Racing
        • Dec 2008
        • 989
        Nice paint job! Post a video when it hits the water.
        • bigpapa
          • Apr 2009
          • 2330
          well ask darin jordan who set up the boat it is very fast and stable in all types of water depending on cog but tks for you advice
          • bigpapa
            • Apr 2009
            • 2330
            i will hopefully this weekend it flew with the bj26 motor cannot wait to test ammo and may put the feigo 12L in it later....... will see
            • Darin Jordan
              • 8332
              First... for oval racing... I'd prefer the single steering rod to "pull" the rudder, rather than push... especially when having to use a bent-up steering rod.
              However, the servo location on this boat was determined by where the steering rod needed to be. That's just where it was when I got the boat from the original builder. It worked fine there originally, and I didn't want to remount all the hardware.
              Honestly, I'd prefer to set the hull up balanced down the center, then adjust weight with things that can be moved... but that's just me. As you can see in this picture from when I originally set this up, the servo weight is balanced by the RX weight.
              Looks good, Todd... Now... stop tweaking it and start DRIVING IT!
              You need to start racing, Dude... ALL of you "Sport Boaters" need to start racing! It'll QUADRUPLE your fun-factor...
              Darin E. Jordan - Renton, WA
              • bigpapa
                • Apr 2009
                • 2330
                you got it my friend tks have a great day !!!!!!!!!
                • Gerwin Brommer
                  • Dec 2008
                  • 918
                  Darin.
                  Oval racings. That makes it all cristalclear :-)
                  As an European i'm not used to oval racing with FE.
                  It's even worse ! We don't race FE cats in Europe !!!!
                  • Darin Jordan
                    • 8332
                    Darin.
                    I'm glad I could help you out...
                    • Jesse J
                      Former scale FE racer
                      • Aug 2008
                      • 7198
                      Does it give you the goofy grin you have in your avatar, Darin?
                      "Look good doin' it"
                      See the fleet
                      • Fastang347
                        • Apr 2009
                        • 97
                        i have driven this boat it just about drives its self very fast and very stable even in a full speed turn....
                        • bigpapa
                          • Apr 2009
                          • 2330
                          #27
                          probaly jesse lol
                          • Darin Jordan
                            • 8332
                            #28
                            It depends on if you where you finish... The higher you place, the goofier the grin...
                            • bigpapa
                              • Apr 2009
                              • 2330
                              #29
                              then you must place high alot lol my friend tks
                              • Darin Jordan
                                • 8332
                                #30
                                He-He... Not as often as I'd like to think I do! But I keep trying...
