Alvin's Renegade Rigger Build
  • sailr
    • Nov 2007
    • 6927
    #46
    Mini Cat USA sells premium quality electric RC boats that come almost ready to run
    rudder
    strut
    stuffing box w/teflon
    flexshaft
    Mini Cat Racing USA
    www.minicatracingusa.com
    • Rumdog
      • 6453
      #47
      I thought about using one of those. the strut has pretty limited adjustability. It can be modded though
      • sailr
        • Nov 2007
        • 6927
        #48
        Whenever we need to restock on the struts, the new ones are slotted so you can adjust. Pretty easy mod to slot the existing ones.
        Mini Cat Racing USA
        • alvinsmith75
          • Jul 2008
          • 635
          #49
          I got my hardware and esc today. The hardware came from ose. I ordered everything seperately, minus the strut because I found that I already had one.
          • alvinsmith75
            • Jul 2008
            • 635
            #50
            Ok got my pistix, will get back to finishing it soon.
            • HOTWATER
              • Nov 2008
              • 2323
              #51
              Awesome Alvin! Depending on your radio...you may not need the Pistix...definately will not hurt if you are unsure. I doubt I am missing out on any speed having one in mine!!! She ROCKS!!!
              KEEP US UPDATED ON YOUR BUILD!! I'm still here if you need anything!!
              -Kent
              "Will race for cookies!"
              IMPBA D12
              My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
              • alvinsmith75
                • Jul 2008
                • 635
                #52
                Thanks Kent. I do need the pistix on the 3pm. Tonight I mounted the servo and hooked up everything. Then I disassembeld. I put a thin coat of epoxy on inner transom and motor mount. Tomorrow I will re mount motor and install top foam and ply, and however far I get.
                • alvinsmith75
                  • Jul 2008
                  • 635
                  #53
                  SSSSLLLLOOOOOOWWWWWW process, waiting for epoxy to dry. The boat looks so good with the epoxy, I am considering going 2 coats epoxy and 1 coat clear. What do ya'll think?
                  • HOTWATER
                    • Nov 2008
                    • 2323
                    #54
                    Do you have any pics? Clear would be cool...it would show off the nice wood tone that rigger has...just make sure that whatever clear coat you will be using will stick well to the epoxy!
                    Hey, have you seen Diego's stretched Renegade build thread? Looks pretty cool so far!!
                    -Kent
                    IMPBA D12
                    • alvinsmith75
                      • Jul 2008
                      • 635
                      #55
                      Finished!!!!!!!!!!!!!
                      Finally got the will to "Get-r-Done. Decided to go with 2 coats of epoxy, I was so happy with the results I left it like that. I can always paint it later if I get tired of the wood grain. NOT Anyway here are some pics. The only thing I am not comfortable with right now is the coupler. It does not fit well on the motor shaft. Correct me if I am wrong, the motor shaft is 1/8th inch? This coupler is too big and created a horribly vibration in the boat.
                      • HOTWATER
                        • Nov 2008
                        • 2323
                        #56
                        I had to drill my motor coupler out slightly to accomodate the 1/8" shaft (too tight) Works great with very little vibration...
                        -Kent
                        IMPBA D12
                        • sailr
                          • Nov 2007
                          • 6927
                          #57
                          apparently you have a 3mm coupler.
                          Mini Cat Racing USA
                          • ace028
                            • Aug 2007
                            • 952
                            #58
                            The motor coupler should be 3mm to .130. That is the one I have on my renegade, and it fits perfect. did you run it yet? Vids? Great work.
                            Twin power =
                            • zanda
                              • 136
                              #59
                              where can i get a kit like this ??? how much ?
                              • alvinsmith75
                                • Jul 2008
                                • 635
                                #60
                                I highly recommend to get it with the motor.
                                Motor coupler I ordered is 1/8th to .130 and that is what the invoice says. Why it is so loose I don't know.
                                I ran the boat this morning but only for about 2 laps. It took on water. I think because I didn't have enough of the teflon tube in the strut. I will make an adjustment and add some heatshrink. I thought the grease would keep the water out but obvisouly I was wrong. The boat seemed to want to walk to the left under WOT, even with the rudder trimmed to the right. Is this normal? What have I done wrong if not?
                                Thanks for the complements,
                                Alvin
