Im about to start laying down the CF Twill, but first I wanted to get a shot of
the inside one last time before It goes in.
This stuff is very annoying, twill will fall all to pieces if its not taped, or
glued were it needs to be cut..I used Medium CA glue and run a bead down
each sides, then were it need to be cut...
after that hang it up so it will dry...
Im also trying to figure out how this motor is gunna fit..the mounts are alittle to tall
an won't allow the cowl to sit flush on the hull..
I order the William's Racing mount and its not going to work because of the water jacket.. and Im deffinatly using water cooling for 5s...
Ill figure somthing out im sure..
