Viva las Vegas BUILD ELECTRIC STYLE
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7119
    #46
    A'ight I got her wet! Weighing in at nearly 6 lbs of raw muscle and a couple of dead nicads (for ballast) she is up and away. Sorry for the vid, had to ask fellow fence post to do camera work.
    I see I need more rudder control as well as a little more strut to loosen her up and reduce the cavitation on the get go.
    All in all, pretty cool. I was afraid she would submarine and not come back up due to the weight.
    "Look good doin' it"
    See the fleet
    • Jesse J
      scale FE racer
      • Aug 2008
      • 7119
      #47
      Originally posted by bustitup
      J
      I got two ul-1 wings to go on my vegas...how should I secure them...I'l also going to checkerboard them just to T you off
      See the fleet
      • bustitup
        • Aug 2008
        • 3071
        #48
        LOL......gimmi some slack bro..........I got four bad boys under construction plus a recovery boat
        And now I have plans for a rc submarine with on board live camera so I can go after my sunken prop....BWAHAHA
        • Rumdog
          • 6453
          #49
          lookin good man!
          • Jesse J
            scale FE racer
            • Aug 2008
            • 7119
            #50
            Nope, no slack. If you had five bad boys under construction, and a hovercraft then maybe.
            I wanna see the Vegas rock some small pond too! Lemme guess, she is waiting for some part.. Ok, well when you find your prop and get all your parallel builds done and you get back from rescuing your submarine then let us know how the Vegas is doin...
            While you are at it, why not build me a rescue boat too, I am comin on a need to buy something......................................... .....
            See the fleet
            • bustitup
              • Aug 2008
              • 3071
              #51
              my rescue project is a little cheapie shockwave 26.... i'm making a 3/4" pvc cage system for the boat to fit into and I'm making it have reverse to manuver better for a boat that gets stuck on the oposite side of the canal we started running in for speed runs...its nothing special but it should work even with the funky strudder system the shockwave has
              • Jesse J
                scale FE racer
                • Aug 2008
                • 7119
                #52
                So have you abandoned this poor show girl or just drowned her in too many projects? Ever getter runnin? I am curious to see what you stink of the handling? getter wet man!
                See the fleet
                • bustitup
                  • Aug 2008
                  • 3071
                  #53
                  with the titan 40 and mean machine pretty much finished I have the show girl back on the bench
                  anyone know the measurement from the bottom of the tunnel to the bottom of the stuffing tube at the strut where it joins the tube?....or at least a starting point?
                  • Jesse J
                    scale FE racer
                    • Aug 2008
                    • 7119
                    #54
                    I'm still tuning, but people say to start with the same depth of the sponsons.
                    See the fleet
                    • bustitup
                      • Aug 2008
                      • 3071
                      #55
                      thats deep J......did you get your new vegas yet?...whats the measurment i asked for?
                      • Jesse J
                        scale FE racer
                        • Aug 2008
                        • 7119
                        #56
                        I go measure now. Yes I got her wet, but it was too high. I dropped it down some and can give you that untested measurement. Is your canal the only place to run boats? why not come on out and we can go to some real ponds here? You will need some room for that lady.
                        See the fleet
                        • bustitup
                          • Aug 2008
                          • 3071
                          #57
                          well after looking at it again its not that deep but will be hard to get a measurement
                          I pretty sure I have decided to use my 1515/2.5d 1650 kv in her with hydra 120 on 5s or 6s....if that esc wont cut ir I have a brand new Turnigy HV 100amp water cooled any opinions...I would like to hit 55 to 60 mph on glass water
                          I'm also going to CF the whole floor for strength and some more weight
                          opinions please
                          • Jesse J
                            scale FE racer
                            • Aug 2008
                            • 7119
                            #58
                            deep is relative. The bottom of my strut is now at the same depth as the sponsons (7/8"). Have you run a hydro yet? You need to go try it.
                            Remember, depth controls the rear, angle controls the bow. If she runs too wet, angle it up (and vice versa). If she cavitates too much drop her down. If her back end is all over the place and doesn't tighten up in the turn, bring her back up a touch.
                            Its a trial and error thing. Depends on your COG, total weight and water conditions. Hydros are the most touchy to adjustments, so do one at a time until you start to get the feel.
                            See the fleet
                            • bustitup
                              • Aug 2008
                              • 3071
                              #59
                              well as luck has it i asked the girl at out LHS if there were any lakes around close and she turned me onto a new park about 10 or 15 min from my house that has a huge huge lake...I went by there and WOW its perfect........you will see it in upcoming vids and pics...it really made my day...now i have to build a 100mph boat...LOL but I may go with gas for the run time also
                              • bigpapa
                                • Apr 2009
                                • 2330
                                #60
                                Good luck on your new water hole lol looking foreward to video
