38" H&M Intruder twin to begin
  • nate
    • 1652
    #31
    Nice Jesse. That boat is sweet, What color is it going to be have you decided.
    LMT
    LehnerMotorenTechnik.com
    • Punisher 67
      Ignore list member #67
      • May 2008
      • 1481
      #32
      Excellent Jesse , also the sponson dropoff angle and distance there wouldn't hurt either . The more detail the better the fit I can give you . an actual template scanned and emailed to me would be the icing on the cake . I can scale it down or up with a photo edditing program
      How thick do you want the mount....? .125 to .187 aluminum is what I would use 1/8 to 3/16
      • Jesse J
        Former scale FE racer
        • Aug 2008
        • 7198
        #33
        Peter, here are your imperial conversions. See what you come up with. I was thinking that since the motors are so far forward (due to space limitations) they will not need more than 5-7deg angle.
        Nate, color? well I have dreamed of silver/black/red scheme but will probably start with colored adhesives until I find something I like/am able to paint. It will probably end up white with some nice accent color(s).
        "Look good doin' it"
        See the fleet
        • Jesse J
          • Aug 2008
          • 7198
          #34
          I was afraid you were going to ask for the angle: 21.8 deg
          Thicker the better, lets go .187.
          I will have to get back to you on the template. See what you come up with in a sketch for the design and I will work on a template.
          this is gonna
          See the fleet
          • Punisher 67
            • May 2008
            • 1481
            #35
            Then...................187 it is
            the measurements are great , template is very important
            are the motors 1515's and how thick are jackets Jesse , Need to know for mounting hight
            As far as mounting a L- bracket on either side of the mount in the center is the best I can think of at the moment , I also have to make a trip into the big city Friday to get the .187 Alum can't find any in the shop long enough , I have to get some other supplies also
            Cheers
            • Jesse J
              • Aug 2008
              • 7198
              #36
              oh, THAT angle, I gave you the one from the ride pads to the chine. I will need to measure that and the jacket thickness. Yes they are 1515/1.5Ys that will go to .078" wire drives. Jeff said he will have struts soon, so things are starting to assemble themselves.
              Thanks Peter, will report back later tonight.
              See the fleet
              • bustitup
                • Aug 2008
                • 3071
                #37
                • Jesse J
                  • Aug 2008
                  • 7198
                  #38
                  ok, those struts are not going to work. Instead I gonna use these.....
                  See the fleet
                  • Punisher 67
                    • May 2008
                    • 1481
                    #39
                    Jesse that 145mm is that on the bottom outside or top inside , starting to draft the rough copy on a grid
                    • Jesse J
                      • Aug 2008
                      • 7198
                      #40
                      All dims are interior. so if you took calipers to the tunnel at the sponson floor, and closed them you would get that measurement. I am heading home from work will try to get you template tomorrow morning.
                      See the fleet
                      • Punisher 67
                        • May 2008
                        • 1481
                        #41
                        Thanks Jesse.................
                        • Jesse J
                          • Aug 2008
                          • 7198
                          #42
                          Ok, got the bulkhead done. iterated between drafting program, printing, taping to cardboard, cutting out, testing, trimming, adjusting in drafting program... etc.
                          Here she is. fits nice and tight without forcing. I will next post one with holes for the motor mounts, but previous drawings place it ok. I know, I know "I want the measurements to be EXACT" Fine, stay tuned then...
                          See the fleet
                          • Punisher 67
                            • May 2008
                            • 1481
                            #43
                            Thats beautiful Jesse , that will be a big help . I will get the Aluminum tomorrow and should have the code written early next week.................
                            • Jesse J
                              • Aug 2008
                              • 7198
                              #44
                              Anything for you Peter. If you want I can export that drawing as .dxf from my drafting program (Canvas). What do you have in mind? I wonder if a mount kinda the opposite of those single motor mounts for rails. 2 pieces, front and back and each mount to the tunnel and maybe to each other with a slider. So, you put in the rear half and bolt it to the tunnel. then you slide in motors, and then slide on the forward half, and tighten the screws on both the motor and the bracket down the tunnel. I recon I will need to draw you my mental image. I will need one motor clamp screw, since it will be tucked into the sponson ooooohh so neatly. I will try to sketch something up this weekend.
                              See the fleet
                              • Punisher 67
                                • May 2008
                                • 1481
                                #45
                                Yes Jesse you will have to draw out your idea cause you have kind of already lost me...........LOL , sure send me the DFX also
                                But I will guarantee you I will try my hardest to make this as close to exactly what you want as I can
